Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#11
Re: Wheels - Centre Bore
1200rallycar
Posted on: 2012/2/27 19:08
Ok this may be an upgrade for extreme situations but its certainely not normal practice, to be of any effect you would need the hub precision machines to a known dimension then machine wheels to suit. Strangely enough I can't remember many dnf from wheels falling off at rallys I've been to/in
#12
Wilfred
Posted on: 2012/2/27 22:34
As has been mentioned here there is no 'hub ring' on the rear. The disk brake front on the ute (which im presuming is from a 120Y) is tapered from the hub to the mounting surface. Thanks for everyones input. Will post a pic in this thread once they arrive.
#13
wards
Posted on: 2012/2/28 2:15
"you can lead a horse to water but you can't make it drink" if you have no problems please disregard all advice offered. sorry guys
#14
1200rallycar
Posted on: 2012/2/28 2:29
no problem with your advice... but it needs to be put in context. what you are talking about is not normal practice, it's a possible upgrade - that sounds like is popular with drag cars?
#15
benny
Posted on: 2012/2/28 3:00
I agree with Wards advice,the "shock loads" of suspension movements should ideally be transferred through correct wheel fitment on the hub. The wheel studs are there to hold the wheel on as there primary function, otherwise they will be subject to "shear" loads and may fail at some point. El-cheapo wheel spacers are a great example of exaggerating the problem, the hub centric type are the way to go.
#16
Wilfred
Posted on: 2012/2/28 4:32
Thanks Wards... appreciate your advice (and the opinions of others). Just to be clear I ordered the centre bore to fit the front hub. (I ended up measuring with a digital feeler gauge). Might as well do it while they are being drilled especially for me. Thanks again everyone.....
#17
supafatto
Posted on: 2012/2/28 21:54
Oi 1200rc!! Back in 70's it wasn't common practice but in the 90's it became standed to spread the load over the hub, rather than putting all the pressure on wheel studs! If you are having custom stuff mad it is better to get the best figment and use a copper or brass anti seize spray to reduce corrosion!
It is much safer to have hub and wheels hole size to suit!
#18
1200rallycar
Posted on: 2012/2/28 23:40
cool, i wasn't being nasty about it, i've learnt something now that it's been explained a bit better
i wouldn't think many people on this site would have hub-located wheels on their car would they? none of my cars do the only cases of broken wheel studs i have come across were created by over-enthusiastic rattle gunners
#19
supafatto
Posted on: 2012/2/28 23:44
I do on my car but not my 1200! Skyline has them and is a 1990 model!
Come see them!
#20
1200rallycar
Posted on: 2012/2/28 23:49
my ae92 corolla has the hub-centre located on the spare steel wheel thats on it atm, so i can see what is possible, but the other 3 mags on it are not located
