Re: Wheels - Centre Bore
From Melbourne, Australia
Ok this may be an upgrade for extreme situations but its certainely not normal practice, to be of any effect you would need the hub precision machines to a known dimension then machine wheels to suit. Strangely enough I can't remember many dnf from wheels falling off at rallys I've been to/in
Posted on: 2012/2/27 19:08
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
As has been mentioned here there is no 'hub ring' on the rear. The disk brake front on the ute (which im presuming is from a 120Y) is tapered from the hub to the mounting surface. Thanks for everyones input. Will post a pic in this thread once they arrive.
Posted on: 2012/2/27 22:34
From windsor, sydney
"you can lead a horse to water but you can't make it drink" if you have no problems please disregard all advice offered. sorry guys
Posted on: 2012/2/28 2:15
WARDMAN ENGINEERING
CNC machining
Race Car Fabrication
Suspension, Brake, Drivetrain modification
TIG welding of all metals
0413 595 627
no problem with your advice... but it needs to be put in context. what you are talking about is not normal practice, it's a possible upgrade - that sounds like is popular with drag cars?
Posted on: 2012/2/28 2:29
1200 Coupe Rallycar
From Sydney
I agree with Wards advice,the "shock loads" of suspension movements should ideally be transferred through correct wheel fitment on the hub. The wheel studs are there to hold the wheel on as there primary function, otherwise they will be subject to "shear" loads and may fail at some point. El-cheapo wheel spacers are a great example of exaggerating the problem, the hub centric type are the way to go.
Posted on: 2012/2/28 3:00
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Thanks Wards... appreciate your advice (and the opinions of others). Just to be clear I ordered the centre bore to fit the front hub. (I ended up measuring with a digital feeler gauge). Might as well do it while they are being drilled especially for me. Thanks again everyone.....
Posted on: 2012/2/28 4:32
Oi 1200rc!! Back in 70's it wasn't common practice but in the 90's it became standed to spread the load over the hub, rather than putting all the pressure on wheel studs! If you are having custom stuff mad it is better to get the best figment and use a copper or brass anti seize spray to reduce corrosion!
It is much safer to have hub and wheels hole size to suit!
Posted on: 2012/2/28 21:54
Edited by supafatto on 2012/2/28 23:44:49
Car free
cool, i wasn't being nasty about it, i've learnt something now that it's been explained a bit better
i wouldn't think many people on this site would have hub-located wheels on their car would they?
none of my cars do
the only cases of broken wheel studs i have come across were created by over-enthusiastic rattle gunners
Posted on: 2012/2/28 23:40
1200 Coupe Rallycar
I do on my car but not my 1200! Skyline has them and is a 1990 model!
Come see them!
Posted on: 2012/2/28 23:44
Car free
my ae92 corolla has the hub-centre located on the spare steel wheel thats on it atm, so i can see what is possible, but the other 3 mags on it are not located
Posted on: 2012/2/28 23:49
1200 Coupe Rallycar
« 1 (2) 3 »
