Re: Eoi 2" or 51mm coilovers
For people's info I was running 190lb springs with 180mm free length, upgraded to 250lb 200mm free length.
The sprung perch is set lower with the new springs but car doesn't sit lower due to stiffer rate and longer free length. It also doesn't bottom out, it did if I set it too low with 190lb springs but x member was at 105mm from ground
Posted on: 2012/3/4 21:27
Oh it also handles better at 140mm than it did at 105mm even though it doesn't look "fully sick"
Shocks are also important, cheap Gabriel's off eBay were well suited to 190lb konis suit the 250lb
Posted on: 2012/3/4 21:30
That right so it depends on total out come to suit your setup! Ie mik says 200mm 250pound springs with konis,
I'll be running 200mm 225pound and bilstine inserts ect
Now the setup in my car has 175pound springs with bilstine shocks but was built for rally!
So depends 100% on application! Race, street, hot street, rally, or what we can afford! :)
The more ppl buy the cheaper it gets as per normal! I'm looking into selling on eBay but not at the price offered to 1200.com
Posted on: 2012/3/4 21:38
Car free
From Florida, USA
Probably handles better at 140 as you have ths suspension bak in its working range. Have you modified the lower control arm with the spacer between the strut and the balljoint/steering arm?
Posted on: 2012/3/5 3:31
Carbon offset purchases are the Environmentalist equivalent of Television Evangelists being caught with Hookers.
No spacer not needed at 140mm as the lca not past horizontal. Still has movement in the arc. And with 250 springs it doesn't compress as far.
Posted on: 2012/3/5 4:01
From Melbourne, Australia
suppafattos pics
Posted on: 2012/3/5 11:17
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Thanks 1200rc and sorry to orange-1200
Posted on: 2012/3/5 11:22
Car free
I'd be intersted but will need it to suit 120y struts
Posted on: 2012/3/6 12:20
MUNCH MUNCH PISTONS FOR LUNCH
From windsor, sydney
hi "unfimilia" you do realize that by changing the ride height you are also changing the roll center height this could be why the handeling results are changing so much, the spacers are to get the roll center in the right place and also run the lower ride height . there is a lot of geometry change in 40mm of static ride height.
Posted on: 2012/3/7 2:54
WARDMAN ENGINEERING
CNC machining
Race Car Fabrication
Suspension, Brake, Drivetrain modification
TIG welding of all metals
0413 595 627
Hi wards, yeah I realize that and that's why went to a ride height where RCA were not required and handling dynamics to front end improved immensely.
I understand the theory in laymans terms, but I'm no engineer so take in others advice and experience.
Might look good being low but handling is more important
Posted on: 2012/3/7 3:19
« 1 (2) 3 4 »
