« 1 (2)
Re: IPRA 1200 coupe at Bathurst 12 hour 2012
From Sydney , NSW
Hey Bryan,
Not Jamie this time - drive was subbed out ......
Impressive for sure. Go to you tube and check out the other Bathurst 12 hour footage - in particular the A9X (#44). His in car shows how skatey the 1200 gets at big speed on crests !!
How is your car going ???? Season is about to start mate ........
Cheers.
Posted on: 2012/3/5 22:28
All torque, no traction
A division of "My mate's ....." engineering
Not too shy to talk
The car has about 380hp on the engine dyno at about 4800 rpm(with the 36mm restrictor)
It has a hilux diff with an 8" crownwheel with a 3.08:1 ratio (this took me 12 months to find!!!)
the gearbox is an Albins 5 speed dog box, (which is just an SR20DET gearbox converted to dog gears) with 5th, changed to first. We kept breaking 5th gear off the end of the cluster (it is in single shear off the end of the cluster, and the HP would just break it off) so we had to get a better gearbox.
the car was white, but we painted it last time the night before a race, so it was falling off!!! so we just repainted it yellow with black stripes in a bit of s 70's colour scheme... attached is a new pictuire of it.
We got 225X50X15 wheels under the flared, but still original steel guards.. Took quite a bit of work, but it needs all the tyre it can get, that is for sure.
It spins the tyres quite a lot over the hump up mountain straight, another competitor said that it actually smokes the rear tyres when it does it!!! Cool!
The car wont be racing again for a little while, as I am racing someone elses car in the sports car series, so perhaps we will have a shot at the IPRA nationals in November in Tasmania...
Thanks for the comments guys..
regards,
jamie
jpg  007.jpg (100.95 KB)
12392_4f5542ad3ea0c.jpg 799X535 px
Posted on: 2012/3/5 22:50
Not too shy to talk
BigV - Still running lots of your bits:
caster bar
rear spring hangers
tail light
Not sure what else, but plenty.
I noticed the flooding recently up your way, and was hoping that 'my' 1200 coupe spares storage area was ok, Im sure I am going to crash it again sometime soon!!!
thanks all your help as always..
-Jamie
Posted on: 2012/3/5 22:54
From Canberra
Jamie,
What clutch are you running, if it is a sprung centre clutch when you transition off throttle the springs unload and it puts shock through the gearbox. If so, get rid of this first, might save a few clusters down the track. IF not might be further upgrades to the gearbox.
Jeff,
What can I say, the build is going slow again. Had some issues getting the new front guards to fit, should be back into it this weekend.
I will be in attendance at the first round, just not with a car, Plus i need the cage rule changes to take effect before log booking the old girl.
Bryan
Posted on: 2012/3/6 0:26
Not too shy to talk
The clutch is a 4.5" 3 plate indy car clutch. it should be ok.
The gearboxes are just not up to the hp, that is about all.
Posted on: 2012/3/6 9:14
From Canberra
yeah it's aways a worry with restricted turbo engines. make bucket loads of torque low down to compensate for the chocked rev range.
Posted on: 2012/3/6 9:36
From Melbourne, Australia
great looking coupe too!
Posted on: 2012/3/6 10:28
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Las Vegas USA
I'm assuming the car the car is at around the 750-800kg which makes for a serious power to weight ratio. Given the 1200's 90 inch wheel base I'm not surprised it's lighting the tires over a hump. Neat video, nice to see a 1200 go like mad.
Tom
Posted on: 2012/3/8 3:38
« 1 (2)
