Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#21
Re: Strong gearbox
D
Posted on: 2012/2/28 10:08
sequential kit for the 71 series! now that I gotta see ;))
Just wondering Don If I got a T5 and A series Bellhousing could you guys make the plate between the two? I wouldnt be able to align it properly. It would need to be a 5mm steel plate then I will have to get the input shaft machined and the auto bellhousing modded for a hydraulic throw-out bearing slave eg by tilton http://www.americanmuscle.com/ram-throwoutbearing-05gt.htm Here is a T5 unit- 160usd !!! http://www.summitracing.com/parts/HRE-82876/ Link below is for a Tremec setup in a ford but would be the same in an auto bell on the T5 box http://www.xfalcon.com/forum/showthre ... 719&viewfull=1#post406719
#22
Re: Strong gearbox
D
Posted on: 2012/3/16 2:52
Sequential shifter also available for the T5
but look at this!! 71 series sequential shifter avail!!! http://www.nengun.com/ikeya-formula/sequential-shifter
#23
Re: Strong gearbox
Dion120Y
Posted on: 2012/3/17 1:14
id say the t50 celica box seems to be the one that most people use if they need a more stronger gearbox, bit expensive for the dellow kit and #OOPS# though
#24
Re: Strong gearbox
D
Posted on: 2012/3/17 1:27
Discussed a zillion times the SilllyKa T50 Hence conversions are always 4 sale.
First gear runs out faster than elevator victims of Pavarotti passing gas. 3.25, 2.9 first is where its at starting with most 71 nissan boxes, followed by T5 & then steel case w50. T50 in a light car & big hp only good starting in 2nd. The cheapest option for a good ratio box weve found with another member is an A series auto bellhousing with 5mm steel tapped and bolted to an S-10 WC T5 box. Front input shaft is removable and T5 would never break. Would prefer a smaller RWD box with separate bellhousing, longer input shafts that can be easily machined to suit and lightweight with good ratios is a big challenge and rare.
#26
Re: Strong gearbox
sikyne
Posted on: 2012/3/17 2:14
Regarding the poridge bowl shifters on the 71b boxes.
I fitted some new shifter bushes (bottom and sides) i recieved from a member in WA. I think they were genuine. It improved the shift a little bit but still not good. Just before the weekends racing i machined up some new ones out of hard nylon. The shift now is great and free from any slop. I dont want people to be put off the datsun boxes because of the shifter, They can be fixed.
#27
Re: Strong gearbox
dattoman_1000
Posted on: 2012/3/17 2:36
I ran the T50 in my track car and the low 1st didn't bother me a bit
I mean really... how often do you actually need to use first gear anyway unless your stop start in peak hour ?
#28
Re: Strong gearbox
D
Posted on: 2012/3/17 2:52
Track and rallye first gear is hardly needed but for street where most boxes end up its not for a light datsun but for a heavy celica. However I thinnk Simon you use the 2.9 first which is an awesome ratio to have.
71 series box sloppy fix also someone mentioned they used soft brass bushes? Hard nylon sounds good specially for those rare and great 2.9 first 260z boxes. T50 weigh is around 32kg as rallycar weighed it some years ago mine weighed 34kg with dellow kit installed while 71 series stumpy box is 35kg and much stronger with 3.25 first gear. To change first gear on t50 its about 800-900 dollars from what Ive read.
#29
Re: Strong gearbox
sikyne
Posted on: 2012/3/17 3:07
The t50 box has a taller 1st(3.58) than the 56a(3.757).
I dont really care about first either. 2nd to 5th is important for me. I need a taller 2nd gear to bring it closer to 3rd.
#30
Re: Strong gearbox
D
Posted on: 2012/3/17 4:04
Yep for racers its a different story.
New thread started to reduce clutter of mix matched opinions for personal needs You can view topic.
