info on ca18 de + t
From brisbane
thinking about doing a de+t on my already ca18de wagon and was wondering what i would need to do. i know i will need a decompression plate and the turbo and manifold and a micro tech or det computer. is there anything else. how different
are the de and det blocks and internals etc.
Posted on: 2012/3/23 0:41
A15 1200 ute, 77 mini -b16a honda vtec project
Re: info on ca18 de + t
From Geelong, Vic
pfft, decomp plate....that just kills all the fun
stock DET parts you need:
Turbo + Manifold
turbo oil line and 90 degree adaptor for the block
Injectors
ECU
Loom, or wire the resistor pack into existing loom and change injector plugs
thats about all i can think of now, all the important sensors seem to be the same, temp sender is a different colour but dont know if it sends a different signal or not
You will need to make up the water lines to the turbo as the DE block doesnt have the hole tapped into the block to suit the stock lines
Then there is the obvious cooler and piping, exhaust ect
No need for a decomp plate if you are just running stock boost, mine was running 7psi. all the decomp plate will do is make it a lower performing engine and less fun to drive
internals are the same, det has oil squirters and 8.5:1 comp pistons compared to the DE 9.5
The block is just missing the tapped hole for one of the water lines to the turbo, and a couple of the hoses on the engine are a little different to suit the turbo water lines
Posted on: 2012/3/23 1:42
From Melbourne, Australia
i was thinking of doing the same
i hadn't thought about the water lines though, good point, there is a place to get the oil supply to turbo?
i would also think you need the DET sump to drain the oil back in from the turbo
Posted on: 2012/3/23 2:28
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Can't you do the punch a hole in sumo and a barbed fitting of sorts?
Posted on: 2012/3/23 2:33
sure but the sump needs to come off to get any metal filings etc out when you do that, so may as well put the proper CADET one back on
Posted on: 2012/3/23 4:27
1200 Coupe Rallycar
From hastings,vic
all the holes for water and oil are there but need to change sump for oil drain
Posted on: 2012/3/23 4:45
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
From brisbane
i have a det engine here but if i dont have to swap the whole lot and everything is the same except the few things mentioned then what the hell. more compression = more fun. are the det and de gearboxes the same.
Posted on: 2012/3/24 8:00
From Brisbane
More compression on a CA18DE = detonation when combined with turbo. You have to tune it with an aftermarket chip or microtech (or similar).
Posted on: 2012/8/25 11:47
From Christchurch NZ
Buy a nistune tool.
You're deluding yourself if you think standard DET maps will work perfectly with a plus T.
So long as you keep the boost reasonable, the higher compression will be okay. Also the turbo will spool faster due to the higher compression.
Posted on: 2012/8/26 10:04
Forced Induction!
your best of just putting a det motor in, there's to much f'n around converting a n/a to turbo. depending what intercooler setup your going to put in you'll most likely have to take the motor out anyway if you have to cut the rad support or anything
Posted on: 2012/8/26 12:49
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
