Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
SU vs Weber 32/36 carbs
AgentWright007
Posted on: 2012/3/26 15:59
Does anybody know the performance difference between a pair of SU carbs vs a Weber 32/36 on an a14? Just curious if it really is worth the cost.
#2
Re: SU vs Weber 32/36 carbs
bakat
Posted on: 2012/3/26 17:42
2 38mm carbs vs 1 32/36. IMHO i'd go for twin hitachi setup all day..
#3
AgentWright007
Posted on: 2012/3/26 18:22
im kinda retarded when it comes to some of the technical details. Im more of a Do-it-yourselfer than a mechanic. So basically the the SU carbs are larger than the weber. What kind of HP difference are we talkin'?
#4
bakat
Posted on: 2012/3/26 19:29
what other mods have been done to the motor? bigger valve, ported head, aftermarket header, cam, stuff like that can improve your ponies.
#5
AgentWright007
Posted on: 2012/3/26 19:32
I have done nothing other than install the weber 32/36 and remove most or all of the emissions junk.
#6
bakat
Posted on: 2012/3/26 19:37
if using dual hitachi's, properly setup, i think 100 HP is achievable. engine hp though. and you need better exhaust system than stock.
#7
AgentWright007
Posted on: 2012/3/26 19:53
Speaking of exhaust, I just got new exhaust Friday. It's still "stock" but it has no cat. I'm not really looking to make it fast just because of the labor and cost. I was really just curious. My goal is to fix the pinion bearing (not myself), fix the tie rod, re-trim the windshield and back glass, finish the interior, finish the bodywork and paint that bastard! I'm finally "almost" there; I can taste it!
#8
bakat
Posted on: 2012/3/27 0:31
nice. there's no tudor sedan in Malaysia.. haven't seen one.
#9
jeffroj
Posted on: 2012/3/27 5:54
I was running 2 SU's on my a14 I bought them new from su midel I loved them after sussing out the correct needles. the Guys at midel are really helpfull. I recon I was pulling around the 90hp mark. Alot of fun.
#10
bakat
Posted on: 2012/3/27 6:47
wheel hp i assume? that should more than 100 engine hp.
