Re: Lca- which to use for bit more track
Well some how had more castor on pass side than drivers and tyre rubbed on guard under hard turning. Might just be a case of more guard cutting required :(
Posted on: 2012/4/2 12:52
From Melbourne, Australia
the problem with all this adjustable suspension stuff... a proper wheel alignment to set castor, toe and camber will cost around $300
but once its it's set once you shouldn't have to play too much, unless you have a rally car too that has a tendency to bounce off solid things
Posted on: 2012/4/2 13:01
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
$300 for a wheelie! Come see my mate then! Crap I could spend all day doing it for that
Posted on: 2012/4/2 13:03
Car free
From Perth WA AUS
My wife has a tendency to bounce off solid things in our forrester (mainly curbs) and she is not a rally driver, imagine if she was.... I would ban her from driving anywhere.
Posted on: 2012/4/3 11:00
Datsun 1200 2Dr sedan.
Lucky she's equipped with fun bags :edit: air bags
Posted on: 2012/4/3 11:05
normally you should have more caster on the left/passenger side to compensate for camber in the road
Posted on: 2012/4/3 13:49
« 1 (2)
