A Series Engine Stand/Rebuild stand
From Ballarat Victoria
Ive just made a few of these to keep my spare engines neat and off the ground.
They would also be good for engine assembly on a bench and for dialing in camshafts.Open in new window
The next version will have a flywheel locking kit(for torqueing flywheel)
Posted on: 2012/4/5 6:45
VIC DYNO HIRE
Re: A Series Engine Stand/Rebuild stand
From Melbourne, Australia
you obviously don't have enough a-series, i would need a "stackable" version so i could pile them up vertically
Posted on: 2012/4/5 7:02
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Lol, I`ve stopped collecting!
Posted on: 2012/4/5 7:08
VIC DYNO HIRE
Ive made a few of these if anyone is interested?
-Aussie steel
-Mitered joins,jigged,welded then linished
-Blasted,epoxy primed and painted
-Black blanking plugs in the front
-4 Rubber stoppers bolted into threaded inserts (to stop it sliding around)
$125. + freight if anyone wants one.
Posted on: 2012/4/12 7:01
VIC DYNO HIRE
From Perth
How tall are they ?
Got a pic with an engine on it ?
Posted on: 2012/4/12 11:00
They are tall enough for the sumps to clear the ground/bench by about 30mm. The top of an A12 block is 35mm below the top of the frame.
The frames are, 410 tall. Not including the rubber feet.
I dont have any pics with engines on them yet.
Posted on: 2012/4/13 0:14
Edited by sikyne on 2012/4/13 0:56:02
VIC DYNO HIRE
From Perth
hmmm...add some casters and they would slide under a bench
Lemmie think
Posted on: 2012/4/13 11:32
A pic with a bare block mounted. I could put casters on them if you`d prefer.
Posted on: 2012/4/14 2:26
VIC DYNO HIRE
