« 1 ... 6 7 8 (9)
Re: ## 1200 and 120y strut and brake upgrades ##
From mandurah
Ok ,ill check that too.
Yea i have the girlock equipt struts
One side sits flush with the gaurds and has probly 0 deg camber ,while the other side has probably 3 or 4 deg negative camber and sits in about an inch
Can't be the gaurds and i doubt its the lcas or anything ,as I was running.a 120y strut setup with no probably and it sat the same on both sides
Posted on: 2012/4/11 16:03
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From mandurah
Problems * not probably
Also what inserts are the go if I shorten them?
Posted on: 2012/4/11 16:05
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
« 1 ... 6 7 8 (9)
