« 1 ... 5 6 7 (8) 9 10 11 ... 17 »
Re: rocketrod's 1200
From Armidale N.S.W
Looks sweet man Will be awesome finished. Glad you left the hooks and rails on hate the shaved look.
Posted on: 2012/4/21 3:47
73 1200 wagon CA project
80 1200 ute Full resto, Ca18det Project.
76 1200 Ute A14, Daily, Soon L18 5 speed.
From Nyngan, nsw Australia
Yeah trying to keep most body parts original on it, other than what's under da hood
Posted on: 2012/4/21 11:17
living is good,.....
The rocket tis home....Tha car has reunited with tha shed 😝 I tell ya what pretty dam impressed with the paint job, like he said better in the flesh, now the fun begins assembling...through sum pics on tonight..
PS: any you guys need of a painter I recommend and a fair price I mite add 😄 st Mary's lad
Posted on: 2012/6/2 23:07
from this in its humble beginnings
to this, iam pretty happy, its only taken 3 years for paint stage...cant rush these things
Posted on: 2012/6/6 11:55
can any you guys with CA18 turbo conversion tell me what i should do with each fitting's/plug's, and what they do?
thanks fella's
Posted on: 2012/6/9 8:47
From Leeton NSW
if you dont mind me asking how much did it set you back for the full respray???
thanks
Posted on: 2012/6/9 14:37
Get in, sit down, shut up and hang on!!!
From South east vic
First pic is knock sensor
Posted on: 2012/6/9 16:07
1200 coupe under construction
Are you talking about the green pipe, ,sorry Ive had nothing to do with the engines before, can I block off any of them or will it effect the engine in anyway?
Posted on: 2012/6/9 22:55
From Sydney
First is knock sensor, you can run without it but it is Advisable to use it . Next 2 are vacuum ports, you can block them off but you will probably need them for your fuel pressure reg and intake butterfly's. Next is a neutral switch, not required. The last is your reverse light switch.
Posted on: 2012/6/10 0:08
Thanks Matt, with the knock sensor is there anything on wiki to see'n read up on about this, id like to know where the go to?,
there 2 plugs on the box, is the front or the rear your talking about!
Posted on: 2012/6/10 1:55
