A12 Distributor Swap to Electronic Ignition
Not too shy to talk
From Pakistan Islamabad
Hello All, I need Help regarding my A12 distributor, its running breaker point system right now and distributor is in pretty bad shape, i want to switch over to Electronic Ignition, the Electronic Ignition conversion Kits are Way to Expensive where i live, i can easily buy a new distributor for the price, Problem: Don't know which distributor will match the shaft lenght and gear... Dont want to Modify until Necessary... any help would be greatly appreciated.. Thanks :)
Posted on: 2012/4/26 2:33
Re: A12 Distributor Swap to Electronic Ignition
From Sydney, NSW
im pretty sure there is another post for this , and i think some people are getting EFI a15 engine dizzy's or E series ones?? anyone else?
and have you checked ebay for the petronix conversion kit? thats what most people use and if pretty cheap
Posted on: 2012/4/26 5:05
Snapped crank and still smiling, How do I do it? LOL
Depends on what you want. Read up on it at EI
Posted on: 2012/4/26 5:44
Not too shy to talk
I will try to find that post, The Petronix CK.. is Way too expensive like i said in My country we have Rupees as Currency, the Petronix kit is 98$ with shipping which is in Rupees 10000, a new EI distributor here cost rupees 3000 :)
Posted on: 2012/4/26 8:16
Not too shy to talk
Anyone??? come on guys??!!
Posted on: 2012/4/27 17:33
Did you read the EI article? It answers your question. There are two distributors with the right shaft.
Nabeel, which A12 do you have? Is it a Premier 112?
Posted on: 2012/4/28 3:18
Not too shy to talk
I dont know if it is Premier 112, the location of the dizzy is at the rear near the gearbox not on top of the oil pump... whic would it be? how can i identify?
Posted on: 2012/5/3 2:46
A Premier is a brand of car. However I see you are in Pakistan so perhaps vehicle is a B310 Sunny?
The EI article lists different factory Datsun/Nissan distributors that will work. If the Pulsar or 1980s Sunny are common in your area, i would recommend the distributor from that.
Posted on: 2012/5/3 3:47
Not too shy to talk
Oh, ok, sorry didn't know that :), Yes i am in Pakistan the vehicle is a B110 Sunny Coupe, what engine came in the pulsar or 80's Sunny? there a few here specially from the 80's...
Posted on: 2012/5/3 5:22
The The EI article has links, photos, instructions, etc. Have you looked at it yet?
Click here -> E15 Electronic Distributor Swap
All you need to use it with an original B110 engine is a little flat plate like this:
Posted on: 2012/5/3 6:10
