Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
15x8
aw
Posted on: 2012/4/26 9:06
I know this has been spoken Bout plenty of times, but I tried searching and couldn't find exactly what I was after..
Will 15x8 with a +25 offset for on a 1200 ute? Just needs know ASAP as I'm holding on a set of wheels, Thanks
#2
Re: 15x8
1200rallycar
Posted on: 2012/4/26 9:42
Try this
Offset Calculator you need backspace around 110mm-120mm width of wheel 8 inches... thats wide...whats min tyre width?
#3
Re: 15x8
Dat82
Posted on: 2012/4/26 10:48
Ive got 15 x 8 rota rbs with 195 55s on the back of my 1200 ute with factory tubs, not sure what offset you need as i am running shortened r31 diff thats shorter than a 1200 diff.
#4
Re: 15x8
aw
Posted on: 2012/4/26 11:12
Dat82- yeah I've got shortened r31 diff also. Back I don't reckon will be much of an issue it's more the front I'm worried about, what are you running on the front?
Rallycar- yeah just tried that and specs showed a backspace of 140mm (5.5") :S
#5
Re: 15x8
1200rallycar
Posted on: 2012/4/26 11:40
well at least that gets you into bolt on spacer territory.... but its not an ideal situation thats for sure
#6
Re: 15x8
Dat82
Posted on: 2012/4/26 11:57
My diff is 1cm shorter each side than a standard 1200 diff so i am running with a offset of +4 on the back, i am running r31 front struts and have got +30 offset rims which just clear the calipers , i ve got 185s on the front but they are just scrubbing on the inside of the gaurd so i am gunna give 175s a go and raise up the front coilovers a bit
#7
Re: 15x8
1200rallycar
Posted on: 2012/4/26 11:59
is that on an 8 inch rim on the front? gonna have some serious strecth with 175?
