« 1 (2)
Re: help advice needed- replacing drag link
Sump won't worry me, it's the angle of the pitman arm to draglink and if its straight or lower on pass side and back a bit
Posted on: 2012/4/26 12:44
Ok so ute and sedan use different part numbers I ordered sedan.
What's the difference between the 2???
Posted on: 2012/4/26 13:08
From New Zealand
draglinks should be the same, but the aftermarket ones are usually off a 120y with a kink in it, whereas 1200 is a straight rod. You didn't import a USA left hand drive one?? have heard of issues with these fitting??
Posted on: 2012/4/26 22:57
It's a new straight one from Dat sport.
I think it's the new idler arm that's the issue not the drag link. The drag link looks identical to the old one. Even entry angles of the tie rods to it.
So poped idler arm off before work this morning, will compare them tonight side by side. Otherwise it might be a bit til I get a new drag link for 120y
Posted on: 2012/4/27 0:37
Ok it was the idler arm. And the new ones bushes are slightly bigger so don't go Ito the old housing. Prob just the model.
They are identical in arm length angle every thing, just the holes are wrong way round. Where on the sedan bolt is on top, on bracket it's down low and vice versa.
So if any one wants to buy a new idler arm.... Pm me, I had to use old one.
Posted on: 2012/4/27 11:08
« 1 (2)
