« 1 (2) 3 4 5 »
Re: Cylinder Head Design - Help, Perth
From WTB 4 speed 60a & vb10 shell
You probably should consider pushrod 3 valve head like one of the aftermarket chevy heads and crossflow keeping all the pushrod gear but using roller cam
Posted on: 2012/4/29 9:40
During times of universal deceit, telling the truth becomes a revolutionary act, Big Brother is watching you - George Orwell
From Perth WA AUS
I think you meant Niel not Nigel ;)
Posted on: 2012/4/29 10:26
Datsun 1200 2Dr sedan.
From Townsville, Qld
...We're still waiting to hear back from that Finnish Man about his venture into building an AY12 style head. The numbers getting thrown around back then were something like 1200-1500 for the basic head that we'd have to get the engine builder to figure out the rocker geometry and stuff.
Posted on: 2012/4/29 11:30
From Perth
Nothing wrong with pushrods and 4 valves per cylinder if you can work out how to do it
http://www.araoengineering.com/
http://www.youtube.com/watch?v=vRKTRLD2h8k
Posted on: 2012/4/29 12:20
Not too shy to talk
From Christchurch NZ - Perth
What happened with the AY12? Has anybody heard from the Finnish man with any updates recently? He hasn't been online since the end of 2008. I think the price you mentioned above is very reasonable for what you are getting in return.
Are there many datsun events in Perth?
Posted on: 2012/4/29 12:51
Nope, I haven't heard a peep, hasn't bothered me greatly since I'm not playing with that sort of disposable income at the moment.
Posted on: 2012/4/29 13:52
From mandurah
we have a few gatherings ,toodjay is the main one ,its a cruise to toodjay when the targa rally is on ,we ride postie bikes around too and talk #OOPS# about datsuns hahah
and cover people that sleep in with water (ass holes you know who you are!)
and no i spelt it right ,nigel*
Posted on: 2012/4/29 16:26
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Advantage of 4 valves over 2 is around 30% more valve area
The complexity & cost required to gain 30% more flow can be surpassed and be cheaper with a good cast turbo manifold, good inlet & correct fueling on an 2 valver A series.
jpg  manifold idea sample for a series.JPG (43.89 KB)
737_4f9e02e86c0f5.jpg 453X216 px
Posted on: 2012/4/30 3:58
From Melbourne/ Adelaide
If you do a search you should turn up discussions on GA16 head conversions for the A series. Bore spacing is the same and apparently only one head bolt needs to be moved 1.5mm. It would probably be the way to go and I thought about it but reality is I don't have the time or money to spend on it. Cool idea though, I hope you get there!
Posted on: 2012/4/30 10:27
Not too shy to talk
D, I have been down the turbo A series route already actually. It will definatley be N/A.
Have done quite a bit of reading on here on DOHC conversions etc. Should have a GA16 head by the end of the week.
Here was my turbo A series I built up-the car and motor has since been turned into a racecar!
jpg  SDC11088.jpg (82.35 KB)
16379_4f9e8937e3214.jpg 640X480 px
jpg  SDC11090.jpg (83.94 KB)
16379_4f9e895d7bc39.jpg 640X480 px
Posted on: 2012/4/30 13:42
« 1 (2) 3 4 5 »
