Re: I Need Help!
Yes, you need help. You could
1. Push-start it
or
2. Replace the the ignition switch (which may have been the original problem). Almost any Datsun 1970-1983 ignition switch is the same except B210.
its almost like it's not getting spark
Test it to see if it is getting spark or not. Pull the coil wire out of the cap, place it 1/4" from the metal, put KEY ON and crank it while you watch. Does it have a fat blue spark? Or a weak yellow one?
Posted on: 2012/5/3 19:49
Subject Poster Date
     I Need Help! AgentWright007 2012/5/3 19:38
       Re: I Need Help! ddgonzal 2012/5/3 19:49
         Re: I Need Help! AgentWright007 2012/5/3 20:08
         Re: I Need Help! AgentWright007 2012/5/3 20:55
           Re: I Need Help! ddgonzal 2012/5/3 22:18
             Re: I Need Help! AgentWright007 2012/5/3 22:36
               Re: I Need Help! ddgonzal 2012/5/3 23:00
                 Re: I Need Help! AgentWright007 2012/5/3 23:23
                 Re: I Need Help! ddgonzal 2012/5/3 23:36
                   Re: I Need Help! ddgonzal 2012/5/3 23:43
                     Re: I Need Help! AgentWright007 2012/5/3 23:47
                     Re: I Need Help! ddgonzal 2012/5/3 23:56
                       Re: I Need Help! AgentWright007 2012/5/4 0:00
                         Re: I Need Help! ddgonzal 2012/5/4 0:06
       Re: I Need Help! jmac 2012/5/4 13:42
         Re: I Need Help! ddgonzal 2012/5/4 18:11
       Re: I Need Help! jmac 2012/5/5 5:53
       Re: I Need Help! bakat 2012/5/5 7:34
         Re: I Need Help! AgentWright007 2012/5/5 14:58
           Re: I Need Help! ddgonzal 2012/5/5 20:08
       Re: I Need Help! Rallytwit 2012/5/5 21:36
