Re: I Need Help!
hi aaron, it sounds like you have been facing two problems:
1. starter had problems. "arcing" the starter with a screwdriver is a traditional way to bypass the ignition switch. If touching a screwdriver between the big starter terminal and the small 'S' terminal worked, that indicates a bad ignition switch.
2. Newest problem. The starter trick no longer starts the car. Now "The engine turns over, the starter engages but its almost like it's not getting spark". Which is way I suggested testing the spark.
Posted on: 2012/5/3 22:18
Subject Poster Date
     I Need Help! AgentWright007 2012/5/3 19:38
       Re: I Need Help! ddgonzal 2012/5/3 19:49
         Re: I Need Help! AgentWright007 2012/5/3 20:08
         Re: I Need Help! AgentWright007 2012/5/3 20:55
           Re: I Need Help! ddgonzal 2012/5/3 22:18
             Re: I Need Help! AgentWright007 2012/5/3 22:36
               Re: I Need Help! ddgonzal 2012/5/3 23:00
                 Re: I Need Help! AgentWright007 2012/5/3 23:23
                 Re: I Need Help! ddgonzal 2012/5/3 23:36
                   Re: I Need Help! ddgonzal 2012/5/3 23:43
                     Re: I Need Help! AgentWright007 2012/5/3 23:47
                     Re: I Need Help! ddgonzal 2012/5/3 23:56
                       Re: I Need Help! AgentWright007 2012/5/4 0:00
                         Re: I Need Help! ddgonzal 2012/5/4 0:06
       Re: I Need Help! jmac 2012/5/4 13:42
         Re: I Need Help! ddgonzal 2012/5/4 18:11
       Re: I Need Help! jmac 2012/5/5 5:53
       Re: I Need Help! bakat 2012/5/5 7:34
         Re: I Need Help! AgentWright007 2012/5/5 14:58
           Re: I Need Help! ddgonzal 2012/5/5 20:08
       Re: I Need Help! Rallytwit 2012/5/5 21:36
