New ute idler arm- only attempted install not used
From Boredomville Melbourne
Ok bought a new idler arm for a 1200 sedan - who knew there were two types?
So will swap for money or two new inner stanza tie rods or a battery box
Will post aus wide for a bag cost of $8 I think they are.
Only difference is where the mounting holes are. 120y, stanza and late utes use these appatently, early models the holes are reversed(so where this is low on bracket is high on car)
Posted on: 2012/4/27 23:31
B110 sedan: L series and 5 speeds, the way they should have been
Re: New ute idler arm- only attempted install not used
Bump-would swap for a motor bike helmet or similar I can use for track days lol.
Or some brake lines- from master to rear and from master to spliter up front.
Posted on: 2012/5/5 11:06
So should fit an 83 ute?
Posted on: 2012/5/5 11:39
Check the bracket but I bought a sedan one and this didn't fit the bracket holes need to be other way round.
It should fit
You got a pic of yours to compare
Posted on: 2012/5/5 13:56
I am miles away from my ute... Can u just use the old bracket? An use the arm and bushes from this one?
Posted on: 2012/5/5 14:43
Could do, I don't try but it looked close. I said it didn't as i didn't pull it apart to try.
Posted on: 2012/5/5 14:55
From Seattle, WA
The 1997 Nissan 1200 catalog says all 1200 utes used the same as sedan
48530-H1000 ASSY-IDLER STEERING [RHD]
But the catalog has been wrong before.
Your photo looks like my LHD 1200 sedan. High and Low.
Posted on: 2012/5/5 20:21
B110 sedan: L series and 4 speeds, the way they were
What years your ute dd? There should be no difference from left to right hand drive either from what im told.
It hole closest to the cabin needs to be don low and the one closest to the front of csr up high I believe
Posted on: 2012/5/5 22:37
From Seattle, WA
I try not to believe fact everything I'm told. Sometime I'm even wrong.
Nissan says (from the parts catalog):
48530-H1000 ASSY-IDLER STEERING [Japan ute]
48530-H1600 ASSY-IDLER STEERING [USA catalog]
I just double-checked this
Let me run out and take photos ...
Posted on: 2012/5/5 23:44
From Seattle, WA
JDM ute late model
USA sedan
Posted on: 2012/5/6 0:02
