wanted alternator
Not too shy to talk
After a working Datsun Sunny external regulated alternator.
Phil - Murwillumbah Northern NSW
Posted on: 2012/5/3 9:40
Re: wanted alternator
I have one that was off a a14 it's listed on eBay
Posted on: 2012/5/3 11:18
datsun a15 ute
From glossodia
I have a 120y and when mine craped out I fitted one from a subara it fit perfect it's a little bigger but the mounts are the same hope that helps
Posted on: 2012/5/5 11:50
only buckets come in five or more litres
From Perth WA AUS
Or you could buy a new aftermarket unit for about $89.
Posted on: 2012/5/5 11:53
Datsun 1200 2Dr sedan.
Not too shy to talk
Thanks guys - my auto electrician says the Subaru L series has an internal regulator and there is a bit of work converting.
Have searched the web for after market and not found any - do you have a site?
Posted on: 2012/5/5 22:24
From Sydney, NSW
i use a mitsubishi one on my a series, 80 amp
Posted on: 2012/5/6 1:41
Snapped crank and still smiling, How do I do it? LOL
Not too shy to talk
Do you know which one and is there much modifying needed?
Posted on: 2012/5/6 3:11
From Seattle, WA
there is a bit of work converting [from Sunny external regulated alternator to internal-regulated alternator]
Yep, sure is. Have to fit one jumper wire, like this:
Subarus with LS T-connector are same as Sunny I/R alternator. Subarus with round connector need to swap the connector.
Posted on: 2012/5/6 3:21
B110 sedan: L series and 4 speeds, the way they were
From sydney.nsw
i've got about 6 or more assorted alternator here, all of a series datsuns, all different brands/types if interested,
Posted on: 2012/5/6 4:00
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS
From sydney.nsw
Posted on: 2012/5/6 4:01
