#1 wanted alternator
philthomas Posted on: 2012/5/3 9:40
After a working Datsun Sunny external regulated alternator.
Phil - Murwillumbah Northern NSW
#2 Re: wanted alternator
datgx Posted on: 2012/5/3 11:18
I have one that was off a a14 it's listed on eBay
#3 Re: wanted alternator
kenoof Posted on: 2012/5/5 11:50
I have a 120y and when mine craped out I fitted one from a subara it fit perfect it's a little bigger but the mounts are the same hope that helps
#4 Re: wanted alternator
levey Posted on: 2012/5/5 11:53
Or you could buy a new aftermarket unit for about $89.
#5 Re: wanted alternator
philthomas Posted on: 2012/5/5 22:24
Thanks guys - my auto electrician says the Subaru L series has an internal regulator and there is a bit of work converting.
Have searched the web for after market and not found any - do you have a site?
#6 Re: wanted alternator
Dion120Y Posted on: 2012/5/6 1:41
i use a mitsubishi one on my a series, 80 amp
#7 Re: wanted alternator
philthomas Posted on: 2012/5/6 3:11
Do you know which one and is there much modifying needed?
#8 Re: wanted alternator
ddgonzal Posted on: 2012/5/6 3:21
there is a bit of work converting [from Sunny external regulated alternator to internal-regulated alternator]
Yep, sure is. Have to fit one jumper wire, like this:
Subarus with LS T-connector are same as Sunny I/R alternator. Subarus with round connector need to swap the connector.
#9 Re: wanted alternator
bige Posted on: 2012/5/6 4:00
i've got about 6 or more assorted alternator here, all of a series datsuns, all different brands/types if interested,
#10 Re: wanted alternator
bige Posted on: 2012/5/6 4:01
