Corolla PanelVan Rolling (I know its not a datto)
Not too shy to talk
From Canberra ACT
AE71 Corolla 2 door custom window van for sale.
Being sold as a rolling shell, the 1JZ and gearbox have been parted out.
1984 AE71 panelvan, converted with Japanese 2 door wagon windows (hard to get! all original Toyota hardware)
Mini tubbed using widened original wheel arches
Pumped/rolled rear guards – lead wiped finish (no bog, no ripples, no sharp edges)
pumped/rolled front guards – all steel
Seam welded rear floor, custom fuel system recess
Custom carpets and trim throughout
JAZ 12 gallon fuel cell
Speedflow fittings & aeroquip hose throughout
custom 10 L stainless surge tank, suit bosch 044 mounted underneath
All speedflow pushlock fittings
Rubber isolation mounts
Bosch VL turbo lift pump
Borg Warner 78 series Diff
28 spline billet axles (5x114.3 PCD)
ARP Studs
Mini spool
recently replaced all bearings/seals
locked axle tubes (bolted to centre housing)
TA Performance alloy hat with cap braces
Recently purchased brand new PBR brake calipers and slotted rotors
ADR approved braided brake lines
Moroso spring saddles suit AE71 leaf spring
Width to suit +25 to +45 offset 9" rim
or 38 offset 10" rim
McDonald Bros racing custom traction bar setup (caltracs)
Aluminium spring eye bushes
Rear leaf helper springs removed, extra full leaf added
Properly lowered (reset by cold pressing)
Poly bushes throughout
custom 10mm spring plates with shock mount
Koni Red adjustable short stroke shocks (revalved for stiffer compression and rebound)
Front struts RA23 shortened 40mm
8kg/mm coilover springs on adjustable platforms
tender/helper springs
Roller bearing top hats
Koni Yellow adjustable inserts
fixed maximum caster & camber (custom camber plates with spherical bearing)
10mm longer lower control arms, poly bushes & recently replaced ball joints
Custom front strut brace
6 point TIG welded rollcage (PCD Engineering) ANDRA tech inspected
Hoppers Stoppers ventilated front brake kit
Ferodo DS2500 pads (used)
slotted discs
custom billet hubs suit +45 offset 8" wheels
15/16" master cylinder (near new)
SW Motorsport Hydraulic handbrake unit (not ebay special)
Includes custom braided line to MC and Diff
Perfect for a multitude of engine conversions, or simply throw in a 4AG on standard mounts to the current crossmember.
Very capable chassis, fitted with heaps of quality suspension and braking parts. Many many thousands spent on development and fabrication with this car, simply part it out yourself and you'll stand to make some easy money - I just dont have the time or the space right at this point.
Not registered, Currently in storage, inspections welcome from serious buyers only.
$3,000
I'll get a couple pics up soon.
Posted on: 2012/5/7 12:14
Re: Corolla PanelVan Rolling (I know its not a datto)
Not too shy to talk
From Canberra ACT
Some pics from last meeting.
Note: It's got a set of R34 GTS rims for the sale. Not the pictured ones.
Hopefully these work.. If not can anyone host some pics?
jpg  P1010577.jpg (181.19 KB)
14790_4fa7b48d321b1.jpg 650X488 px
jpg  P1010566.jpg (198.04 KB)
14790_4fa7b4a42362b.jpg 665X499 px
jpg  P1010575.jpg (183.16 KB)
14790_4fa7b4aeae5d2.jpg 618X464 px
jpg  P1010578.jpg (161.71 KB)
14790_4fa7b4bb67484.jpg 650X488 px
jpg  P1010572.jpg (195.42 KB)
14790_4fa7b4d5a8ff2.jpg 650X488 px
Posted on: 2012/5/7 12:46
From Perth WA AUS
Looks pretty good to me and for the price of a respray!!!!
Awesome value.
Posted on: 2012/5/7 12:58
Datsun 1200 2Dr sedan.
nice rig for the price I agree with Levey
if it was a sunny wagon itd be super value :)
Posted on: 2012/5/7 15:34
Not too shy to talk
From Canberra ACT
This is now sold. Wheels are still for sale.
Posted on: 2012/5/9 11:42
