#21 Re: My s/c a14 is chug chug chugging
blown1400 Posted on: 2004/3/17 10:17
good point B120dat, hadn't thought of that- will drain the tank and see how I go with new fuel...
my last 1200 coupe had a similar problem with old fuel from a jerry can- new fuel and all back to normal.
#22 Re: My s/c a14 is chug chug chugging
B120dat Posted on: 2004/3/17 10:27
check ur fuel filter to....give it a blow see if any crap in there...cause could be shiit in the lines from the tank as well.
#23 Re: My s/c a14 is chug chug chugging
SaltwaterCowboy Posted on: 2004/3/26 3:42
Hey its been a while now,
What was the problem? Does it go like stink again? What happened
#24 Re: My s/c a14 is chug chug chugging
blown1400 Posted on: 2004/3/26 9:41
Hi Salty, number of things made the damn thing run like a hairy goat.
First, a bent needle in the SU. The needle bent just a tiny little bit (like a few thou') and was scoring on the main jet.
Second, a small air leak through the inlet manifold gasket. After some thought, I did remember that it looked a little dodgy when I put it on and thought that it would need replacing at some stage....seems sooner rather than later now.
I am putting a new one in tomorrow
Then... torture some rear tyres
hey just another thing, anyone have any thoughts on gasket goo? i don't use it generally and wonder if i should...??
#25 Re: My s/c a14 is chug chug chugging
pro-240c Posted on: 2004/3/26 9:59
i only use CAT blue gasket compound, never any of this repco budget gasket kit sh1t.
CAT use the stuff for replacement head gaskets (instead of the gasket) on their turbo diesel V16 power generators.
if it's good enuf for that, it's good enuf for an inlet manifold gasket / carb gasket etc.
#26 Re: My s/c a14 is chug chug chugging
A14force Posted on: 2004/3/26 10:03
If your flanges are all nice and flat, you shouldnt really need goo. I've made all my gaskets out of some stuff called nebar. Its a bit like cork gasket material but way more hardcore. (chemically resistant) so I wont be needing goo on those , ind I think the stuff on a manifold gasket(onto the head) should be suffeicent for sealing.
But no doubt someone else will disagree.
Also , god willing i will finally begin to fit my s/c tommorow.
« 1 2 (3)
