What paint striper to use??
From NSW
Hi all, i am getting to the point where i have my engine bay dry fitted and i am wanting to start paint striping the car to see what's underneath...
Has anyone use paint striper and what have you found works well?
Posted on: 2012/5/14 10:46
Re: What paint striper to use??
From Sydney, Australia
Any will do. Just put it on thick, and don't let it dry out. I've heard of people wrapping the panel with cling film so all the nastiness in the stripper can do its job. Getting a good scraper also makes the job easy.
Posted on: 2012/5/14 10:55
From Goulburn NSW
i bought paint stripper from supacheap worked fine.
Posted on: 2012/5/14 10:58
From SA
POR 15 very very very good stuff !!!
Posted on: 2012/5/14 12:15
From vic
I always rough out the paint surface first with gritty sand paper so the stripper has somthing to grip to and it work fairly well. I think i used K and H pink tin or maybe it was brown?
Posted on: 2012/5/14 12:24
From Perth WA AUS
yep, strippers like it rough. It helps with intercoat penetration and speeds things up.
Posted on: 2012/5/14 12:30
Datsun 1200 2Dr sedan.
I used some industrial stuff from my local paint shot that supplies all of the local panel beaters, awesome stuff and from memory it was around the 25 dollars fro 4 litre mark.
Posted on: 2012/5/14 12:37
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
From NSW
thanks for all the info so far...
how much paint striper would i need for the whole ute?? any idea?
Posted on: 2012/5/14 12:39
This is just my 2c, but I've had trouble over the years with paint stripper never totally getting removed, and paint eventually peeling, or bubbling here and there.
It's not cheap, but I honestly reckon sandblasting (or blasting with some sort of abrasive media) is a far better bet. The paint seems to go on better and last longer.
I don't have any 20 year old paint jobs to compare it to, but I am talking about 5-10 years sort of thing.
Posted on: 2012/5/15 7:54
John McKenzie
From NSW
i always though that sand or soda blasting was the way to go also.
but i have been talking to a few panel beaters, quite good ones i might add, and they have all said that paint stripping, although more mucking around and annoying, is probably the better way to go.
They also added that if the person doing the blasting is not very good he can do more damage than good...
Posted on: 2012/5/15 8:04
