Re: 5 speed gear box
If you want a good 5 speed just contact the man himself Mal or Weekend1000
http://datsun1200.com/userinfo.php?uid=9068
but dont waste his time with offers as he can sell them much more expensive if he
really wanted to but doesnt, best price and best service on this forum.
Posted on: 2012/4/19 3:17
From Fremantle, West Australia
60 series 5 speeds came from some B310 (Sunny)
2 types : dogleg and standard pattern
Posted on: 2012/4/19 3:23
From Perth WA AUS
Well said D, could not agree more.
Posted on: 2012/4/20 12:34
Datsun 1200 2Dr sedan.
As Levy and other know few peeps can supply such important rare items and for such a long time on this forum. It keeps people restoring datsuns.
Posted on: 2012/4/20 13:29
All need some mods to use in a 1200. All A-series 5-speeds take a different rear crossmember than the 1200 4-speed. And the 60-series backup lamps switch is a problem
Other than that, the 60-series or 56-series 5-speeds are a bolt-in job. Same tailshaft even as the 4-speed
Posted on: 2012/4/20 22:04
does anyone have any drawings or measurements that detail the required mods to the rear cross member to slot a 63 series into a 1200 ute?
My box is being rebuilt 200km away, and I would like to get hold of a second cross member and get it modded to suit, so when the box is ready it can be bolted straight in, as my box rebuilder has a hoist, and theplan is go down there, get the rebuilt box fitted and drive home the same day.
Posted on: 2012/5/17 3:25
From mandurah
Rooster !
I used a Nissan Silvia rubber mount as it bolts on (same mount as rb20/25) then i used a peice of angle iron that's 4mm thick and just sits in the bottom of the rubber mount ,I then drilled 2 holes ,one on each side of the tunnel for bolts To go through and mde 2inx2in plates to.go on the inside of the floor ,then just bolted it up
Passed the.pits no problems
Reason why i.did this was cos the factory nut things that are welded into the floor got ripped out when I did a burnout or 2 ...... or 4 pairs of tyres worth :D
Also mal is top notch always helpful and fair ,if theres something wrong with the box he will tell you :)
Posted on: 2012/5/17 3:41
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Thanks for that Jesse. I dont suppose you would have any photos of yours floating about? I "think" I get wghat you are on about, but want to be sure.
Also, I have no idea who "mal" is. My box is being rebuilt by a mate in Bunbury, not a shop.
Posted on: 2012/5/17 4:32
From Perth, West Aussie
I heard on another forum that there is a guy that goes through asia buying up a series 5 speeds. But I never found out who it is.
The factory overdrive 5 speeds can be a bit weak as the overdrive part sits in a extension housing the the back of the usual 4 speed case and this part doesnt always get oil to it during hard cornering or going downhill. I always thought it would be more cost effective in the end to get a bellhousing from somewhere such as dellow and install a smooth shifting , reliable celica T50 gearbox. even though it's got a toyota logo on it..
Posted on: 2012/5/17 4:39
From Perth WA AUS
This is Mal ( posted by D ):
Posted on: 2012/5/17 12:20
« 1 (2) 3 »
