I need help with items for my engine........
From Brisbane, QLD
Hello all, I am rebuilding a A12 in the near future and I am wondering about some things. i am getting my p's, so i can't have any visible upgrades ;) i have looked at tech wiki, but i can't make sense of some things. i am orienting it for acceleration, not top speed
1) what oval port head do i get for my a12 (1976 model)
2) do i need double valve springs?
3) what is the best sized radiator i should get?
4) do i get flat top or dished pistons?
5) is it worth getting a lumpy cam?
6) if i do upgrade to an oval port, is there a manifold that has the same carb on it as the circle port?
If some of these questions are dumb, just tell me haha, I just thought I'd get info from the pro's instead of interpreting it wrong from the tech wiki.
EDIT: my a12 is the standard one if that helps, like this one...
Posted on: 2012/5/20 8:59
71 B110
Re: I need help with items for my engine........
From vic
I would also want to know if a long duration camshaft is worth it obviously not with a stock carb but what about with a weber dgv? without hurting too much low end what would be a good spec regrind? also would double valve springs be needed to stop valve bounce?
hope im not interfering with your post but i thought the answers would help you out aswell:)
Thanks!
Posted on: 2012/5/20 9:15
From sydney.nsw
you can do a number of things, all depends on budget,
a14 internals inside a12 block.
oval port head & double valve springs, ( h89 or gx ported ).
big bore 76mm
higher comp makes better power/torque. (if combo is right)
nice cam. (dailed in).
good extractors & exhaust.
electronic dizy.
go around carby. (eg;32/36 jetted)
list go on.
heres some examples of what could be done.
i've got most things in stock or can do, if that helps. cheers
Posted on: 2012/5/21 0:54
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
From Brisbane, QLD
thanks mate, ill look into all of those, i have untill january next year to prep the engine, so i might make up a list of things similar to above and knock each one off slowly :)
Posted on: 2012/5/21 10:57
71 B110
The stock A14 cam is longer duration than an A12 cam. It will wake up the engine between 5-6,000 RPM in combination with the A14 head and Weber DGV 32/36 carburetor. Use 1.75" exhaust.
Posted on: 2012/5/21 19:53
