« 1 2 (3) 4 5 6 »
Re: Engine validation urgent. [PLEASE HELP ME]
a15 stuff all heavier than a a12- more weight over the front axle makes it handle worse- more over the rear axle helps a little i found.
Posted on: 2012/5/20 15:47
Yes, sedans of all brands have more weight over the front wheels than the back wheels -- even with the A12. So more weight in the back will help it handle. More weight = less cornering capability, but handling will improve.
Posted on: 2012/5/21 0:09
From Trinidad and tobago
Thanks Guys,I have b310 Struts so that hold up preety well.
haven't baught anyparts as yet, Could a12 timing chain work on the a15 ?
Posted on: 2012/5/23 3:07
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
yes, A12 and A15 timing chain are exactly the same. The stock Datsun part is a very reliable very sturdy dual-roller chain.
Posted on: 2012/5/23 3:23
Starting to like these A Series Engines even more.
Posted on: 2012/5/23 17:46
Street Sleeper!
Howdy guys,iM inquiring on settings for valve clearence on the A15 engine,Both Hot and Cold?
Posted on: 2012/5/27 3:23
Street Sleeper!
Should be same as a12??? Is it in wiki??
Posted on: 2012/5/27 3:27
I Found out that another member wrote
The specs are 0.25mm cold, 0.35mm hot.
Posted on: 2012/5/27 4:16
Street Sleeper!
Currenty running a sunny B11 Radiator which looks like a 1200 one.Will it cool the engine enough or do i need a 3 core one?
Cheers Darren.
Posted on: 2012/5/31 20:11
Street Sleeper!
yes, a B11 radiator will cool a 1.5 liter E15 engine, it will do the same for a 1.5 liter A15 engine.
Posted on: 2012/5/31 21:27
« 1 2 (3) 4 5 6 »
