« 1 (2)
Re: Stock heater switch wiring help
From MOOROODUC. Victoria
if you're running the stock heater then the Blue/White is only powering the fan and therefore does not draw too much power.
I noticed that you have another thread that shows an electric demister which would contain its own heating element, this may draw power that a relay could help with.
If you are doing the demister with the standard heater controls (ignoring the original fan) then your diagram just above is fine. Connect the source of Blue/white to 86, yellow to 85 - this will give you a circuit when you flick on the switch (but only one speed)
connect high ampage to 30 via a fuse and from 87 to your heater positive. the relay will click across allowing positive power to the heater when the 86 to 85 is live.
Again, in other words, if battery voltage is applied to the relay coil (terminals 85 and 86 as an electro magnet) terminal 30 will be pulled across and connected to terminal 87. at least this is how it should work
jpg  relay2.jpg (63.19 KB)
8710_4fb9b00b3b893.jpg 774X481 px
Posted on: 2012/5/21 4:02
Yep thanks- that's what I needed. Once again I'm over analyzing stuff
Posted on: 2012/5/21 4:21
Tell me about it .... tried 5 different ways to work out the problem with temp gauge getting electrical interference from engine - turned out to be dirty connection to the sender on the CA18
Posted on: 2012/5/21 4:37
Done did like you said no ground on 85 pin- just went to switch wire yellow wire. It's 1:45 lol can't sleep will test it tomorrow.
Posted on: 2012/5/21 16:46
« 1 (2)
