#1 Mikuni carbs ???
SaltwaterCowboy Posted on: 2004/3/27 6:57
Hey has anyone ever run Mikuni carbs on there dat? How bout the Lynx manifolds?
Are they any good?
#2 Re: Mikuni carbs ???
A14force Posted on: 2004/3/27 7:27
They are good carbs ,but as I understand it they are orphans now.(cant buy parts for em)
If someone knows were to get bits, sing out a mate of mine has a pair that need parts.
#3 Re: Mikuni carbs ???
ade Posted on: 2004/3/27 10:56
they worked a treat on EB1 Honda civics but I never came across a parts list for them.
Would a similar bike carby setup do the job with less hassles??
#4 Re: Mikuni carbs ???
sarav1200 Posted on: 2004/3/27 13:08
Hi
I'v worked in the carburettor industry going on eleven years. Mikuni/Solex sidedraft parts................GOOD LUCK.
Unfortunatly nothings available.(New)
If ANYONE can find a supplier I would love to know about them.
#5 Re: Mikuni carbs ???
89mm Posted on: 2004/3/28 12:21
Good Luck is not the issue.
I run 2 X 44mm Mikuni's on my 1475 cc A14 and can tell you that they go REAL well.
For Parts, contact Lou. Mondello, the Sports 2000 guru, phone (03) 9555 9591.
He brings parts in from all over.
#6 Re: Mikuni carbs ???
89mm Posted on: 2004/3/28 12:24
I probably should have added for Salt Water Cowboys benefit the lou operates out of his Workshop in Moorabbin, a suburb of Melb, Oz
StewMck.
#7 Re: Mikuni carbs ???
sarav1200 Posted on: 2004/3/28 12:36
Hi 89mm
Does Lou supply new Mikuni/Solex PHH sidedraft parts?
When I wrote Good luck I meant finding new parts. I KNOW they go well.
#8 Re: Mikuni carbs ???
89mm Posted on: 2004/3/30 1:16
I've never needed a loy of parts, but Lou has always come up with the goods. Gaskets, diaphragms, jets etc. Probably best to give him a bell.
#9 Re: Mikuni carbs ???
89mm Posted on: 2004/3/30 1:17
#10 Re: Mikuni carbs ???
1000wags Posted on: 2004/3/30 5:49
i ran a set of 40mm on my L20 and they ran great, finding any spare parts is hard though.
a friend of mine has a lyn manifold it its runners are rather small in diameter, alot smaller than his ports but of course you could always match the ports with a grinder.
