« 1 (2)
Re: Fuel Reg.and Pump Help!!
From Christchurch NZ
not fatal, just that the fuel will blow past the needle and seat and she'll flood.
Posted on: 2004/3/29 0:15
Forced Induction!
From Perth W.A
Do you need a pressure regulator if you have a electric fuel pump cos i just got one from a friend for free, so i was wondering, what would happen without one? i'll be running a 32/36 when i install the pump
Posted on: 2004/3/29 2:57
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
From Auckland N.Z
you be running at full presure (10 - 12psi depending on the pump) and you'll get what a14force said and it wont work. If the car is reasonbly stock then running the standard mech pump is fine even with a 32/36.
Posted on: 2004/3/29 3:46
From Perth W.A
the plan is to go to an L18 or CA18 i know the pump won't cut it for the CA18 but i'm sure it'll be fine for an L18, where can i get these from? does Enzed have them or EARLS? it self primes so do i need to put it at the same level as the tank or can it be above it? sorry for all the questions but i would like to get it right first time!
Posted on: 2004/3/29 5:39
120y Coupe
From Auckland N.Z
As long as the motor runs carbs the pump will be fine if its a carb pump (efi needs way higher Pressure) its the volume thats the issue with the standard lines as for the pump you have my holly is self priming and it sits about afoot above the tank and its sweet. run a mock set up and hold the pump up high and start it youll know if its working
Posted on: 2004/3/29 13:45
From Christchurch. NZ
A friend of mine mounted his electric pump in the engine bay, He found when going up a steep hill the pump draw was not enough and had to move the pump closer to the tank. It was so bad he had to roll down the hill and get a run up, needless to say he changed its position as soon as possible. So it is your decision where you want to mount it, but if you do decide mount it in your engine bay then keep this in mind.
Posted on: 2004/3/30 10:49
« 1 (2)
