« 1 2 (3) 4 5 6 »
Re: Cylinder Head Design - Help, Perth
From Christchurch NZ
Well I have been slowly working away on this. I caught up with mike (dundee1000) and borrowed a h89 head.
I bought a GA16DE head but I still need to confirm I can use the camshafts with the bore spacing being slightly different to the A series.
The model has been progressing aswell. Could upload a picture or two as well...
Posted on: 2012/5/23 13:18
From Perth, West Aussie
what happened to the mazda DOHC head that someone on here was toying with modifying to fit an A series some years ago? did they end up getting it to fit? I stopped coming on here for a while when I jumped camp to toyotas (well I sold all my cars but I don't really have an allegiance per say, but still believe toyota make better gearboxes and diffs ;)
also did the guy that was trying to get an E15 to fit a RWD gearbox end up finishing his project?
Posted on: 2012/5/23 16:00
I, for one, would love to see a pic of your model. Purely from a proffesional inters=est point of view (another 3D modeller here)
Posted on: 2012/5/24 1:35
GA head is better than Mazda as it has ideal valve angle narrow head
The wide mazda head is old stuff 50 degreess versus the ideal which is
now halve of that at 25 degrees. The only downfall of the stock GA is
the ports are small but American tuners have found heaps of meat in
port area that can be removed to improve flow by 60% more!
If you can make a 3 valve pushrod head using the ARAO 4 valve like layout
youll have more than a couple of buyers here.
Posted on: 2012/5/24 3:21
From Coondle, WA Australia
Yeah. It fits. The E15 bolts only an a-series box, bar one bolt. It works fairly eaisly. I have one sitting in my shed if you want to come look. The only real problem is that the dizzy is in a #OOPS# of a position, but thats overcome with some lateral thinking.
Posted on: 2012/5/26 1:00
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Megajolt jnr from autosportlabs.com is our mate only 169usd for crank fire ignition no more dizzie then electric water pump feeding off side welsh plug closer to front & radiator. GA16DE better head but e15et is simple & light.
Posted on: 2012/5/26 4:48
I have been working away on this slowly, here are some pics of the progress.
I still have to model the oil galleries and water galleries and play around with different ports using flow simulation
At the moment it is GA16DE cams, valves buckets etc
Comments or opinions are welcome!!!
jpg  11_05_-8133.jpg (76.70 KB)
16379_4fd1e1f55a938.jpg 1507X737 px
jpg  image009.jpg (92.77 KB)
16379_4fd1e2b7ae4e0.jpg 1433X792 px
jpg  image010.jpg (86.73 KB)
16379_4fd1e34953f9a.jpg 1438X748 px
jpg  image005.jpg (62.01 KB)
16379_4fd1e383b9cb7.jpg 1423X734 px
Posted on: 2012/6/8 12:39
From Malaysia
at the rocker cover, put DATSUN instead of NISSAN.
Posted on: 2012/6/8 15:28
Very very nice work, just so you know there is also a more commonly available engine you can pinch the cam gear from it has a much simpler exhaust slave cam setup found on countless late 80s and 90s corollas the 4afe or 7afe.
248hp from a 4afe has proven modern narrow valve update is even better than any formula atlantic 4age or 20v 4age wide angle valved heads.
http://board.tercelonline.com/viewthr ... ction=printable&tid=45398
if you look at the slave cam with single belt driven setup it could be much easier to be modded on an A series.
http://forums.club4ag.com/zerothread?id=11272
jpg  4afe.jpg (68.39 KB)
737_4fd20f11a87a2.jpg 440X380 px
jpg  4afe2.jpg (54.54 KB)
737_4fd20f190a9a6.jpg 270X305 px
Posted on: 2012/6/8 15:36
From Malaysia
any chance you cut put 2 plug per cylinder? the more the merrier.
Posted on: 2012/6/8 15:53
« 1 2 (3) 4 5 6 »
