Castle nut and washer for stanza stub axle?
From Narellan,Sydney
Any1 know where I can find a set of these? Thanks
Posted on: 2012/5/31 0:19
Re: Castle nut and washer for stanza stub axle?
From Canberra
I'm not sure about a fastener's joint in sydney.
But i use specialty fasteners here in canberra and can get anything. If you want send them an email with the bolt's you need what type i.e high tensol and head type (castle nut) plus thred i.e 10x1.25 and they will send them to you.
http://www.specfast.com.au/contacts/
Otherwise there are these boy's in kirrawee
http://www.southernfasteners.com.au/contact
http://generalfasteners.com.au/contact-us/
Just Found these guys in sydney
http://aerobolt.com.au/contact/
So i'd say give them a call and get the bolts sent your way..
Hopefully this helps
Posted on: 2012/5/31 0:36
From Canberra
Just did a quick look up in yellowpages.
http://www.yellowpages.com.au/find/fa ... strial/greater-sydney-nsw
That should give you a nice listing of all the fastner joints in sydney
Posted on: 2012/5/31 0:43
Ok thanks heaps do you know what the thread size is for stanza stub axle?
Posted on: 2012/5/31 0:46
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
From Canberra
Unfortunately i am unsure of what the stub axle thread would be on the stanza.. i attempted to check the tech wiki but there are no stat's on the thread.
Only thing i can suggest is use a thread pitch gauge to measure the thread. If you don't have a thread pitch gauge you can pick them up nearly any hardware place for around $10-$15 so you have an accurate reading of the thread
http://www.ebay.com.au/itm/WHITWORTH- ... evels&hash=item2c657706e0 << clicky
You prob's don't need one with that many thread gauges but never the less may come in handy later
Posted on: 2012/5/31 2:07
FWD Stanza or RWD Stanza? Front or rear hub?
It's probably the same as 120Y
Posted on: 2012/5/31 2:26
Look like front struts and front hubs
Posted on: 2012/5/31 5:11
