Stock A12 bogs in 3rd oand 4th gear WOT!!
Not too shy to talk
From Pakistan Islamabad
Hi All, I finally got my A12 started and the Dato is back on road, washed the fuel tank, rebuilt the carby, and put a resistor to the 12v Coil, and Got a new Electric Fuel Pump, The Car is running fine so far, but bogs down on WOT in 3 and 4th gear, no problems in first and 2nd, when you suddenly hit the throttle the engine bogs for like a sec (on Idle)...
Posted on: 2012/6/1 2:20
Re: Stock A12 bogs in 3rd oand 4th gear WOT!!
This symptom can have many causes.
Check your fuel pressure. It should be below 3 psi. If it is not, try the old mechanical pump, which are excellent high flow units.
Check the fuel flow. It should be more than 1/2 liter in 60 seconds.
Posted on: 2012/6/1 2:34
Not too shy to talk
HOw do i check the fuel pressure?? i had to put a return line because of the pump pressure,the carby would overflow without the return, could it be the float level??, and i forgot the exhaust is leaking from the manifold and pipe joint due to one of the struts slipping, no low end torque
Posted on: 2012/6/1 10:21
Fuel pressure is most likely the problem. Carburetors like around 3 psi. Even weber carburetors, or datsun carburetors.
Check your fuel pump pressure rating on the label or instructions. You check the pressure by using a pressure gauge. Often this is built into a mechanic's vacuum gauge.
Or just use the stock fuel pump, which is good for double the horsepower of a stock A12.
Posted on: 2012/6/1 10:24
The exhaust leak should not cause a power or driveability problem.
no low end torque
First correct the fuel pressure issue. Then see how it works.
Posted on: 2012/6/1 10:26
Not too shy to talk
Okie... Thanks.. will update
Posted on: 2012/6/1 10:44
