A12 Tuning/Rebuild
Hi all, I've got a 79 sunny b310 with a stock a12.
It blows a bit of smoke, and has a knock (Mechanic thinks piston pin knock)
I have considered getting it rebuilt, or just getting a tune
Does anyone have any info on how much better the engine performs after a tune?
And a bit of a long shot here, but is it worth the money getting it rebuilt?
Any help appreciated
Cheers, Zak
Posted on: 2012/6/2 13:18
Re: A12 Tuning/Rebuild
A "tune" won't stop a piston pin knock.
A tune costs no money.
A tune is worthwhile. See Tune-up
Posted on: 2012/6/2 20:49
Because it is smoking, you should find out the cause.
* If it is due to low compression, then put new rings in it. Measure the pin clearances when you do this and replace as necessary.
* If it is due to worn valve guides, have the head rebuilt
It depends on how it is performing now. Power and fuel economy are your indicators. Power can double after a tune-up -- if the power is down now. Fuel economy often goes up 20%. But if it's already good, then a tune won't help much if at all.
There isn't much to a tune-up on an A12. Usually it does not require any new parts except new points. Just re-torque the head gasket, re-gap the sparkplugs, search for and fix vacuum leaks. Inspect the cap, rotor and plug leads, only replace if damaged. Replace the points then set timing and mixture. Enjoy.
That depends on you. If you really don't like the car and would rather have something else, why rebuild it? Just sell it. On the other hand if you love the car, maybe it's worth it. I would just find a good used A12 for $200 to replace your bad one. Of course with a used engine, it needs testing. Same as your engine you have now.
Posted on: 2012/6/3 6:04
Thanks heaps DD, you seem to be an absolute guru.. I'll definitely be looking into a tune, the only reason I'm considering a rebuild is that I question my cars' reliability.
Posted on: 2012/6/7 9:38
