How to ID a ca22
From South east vic
I bought a ca22 but need to confirm it, it's ment to have a ca20 crank and oversized pistons in a ca18det block!
Any help/ideas please
Posted on: 2012/6/6 13:19
1200 coupe under construction
Re: How to ID a ca22
From Sydney, Australia
ca20 crank will have a smaller (compared to ca18) front pulley hole. The front of the crank is about 5-6mm smaller in diameter where the front crank pulley pushes on.
When you pull the head off, it's easy to measure stroke and diameter.
If it turns out to be lies. Then the offending parts should be inserted without lube, into the tail pipe of the seller.
Posted on: 2012/6/6 13:32
From South east vic
Yeah well the motor was ment to "be a good runner" yeah comp is 125,70,60,100 so that's bs, ect so I'm almost sure I got bs! And bought the hole car on eBay, and they will do nothing about it!
Posted on: 2012/6/6 13:42
should be closer to 180 for a ca18det. Don't get too depressed just yet. Measure it up and see.
If it's got some good parts, you could still part the motor out for a fair bit of cash.
Posted on: 2012/6/6 13:54
From South east vic
Need to measure it but don't want to take off head just yet, any hints
Posted on: 2012/6/6 13:57
Sorry to hear that mate
Supafatto, maybe try and post up wrecking exa ads on gumtree or exa forums and hopefully get some or most of your cash back mate.
and if not interested in engine, maybe sell off parts.rocker cover,manifolds etc
and No offence meant but ca22det is just a myth unless proven otherwise.
Posted on: 2012/6/6 13:59
From South east vic
180 boys use a ca20 crank and bigger pistons so it is possible to make it work!
As for the exa I've got it up on eBay as parting out! But gotta go over the car and see what's good or not good then will post Fs adds
Posted on: 2012/6/6 14:02
There was never a factory-produced twin-cam CA 2.0L motor, nor a turbo version. However the blocks are similar, and it is possible to fit the DOHC CA18DE/T twincam head to the SOHC CA20 block. However the DOHC/SOHC manifolds are different and the timing pulley/belts are not compatible. Despite this, CA20DET turbos have been built. The cheaper alternative to a CA20DET is a newer SR20DET. Parts for the SR20 are less expensive and more readily available. Tomei and JUN of Japan produced 2 litre stroker kits for the CA18. A company called Norris Designs produces a CA20 stroker kit as well as a CA20 engine.
quote form wiki suggesting pulley/belts from ca20 not compatible?
Posted on: 2012/6/6 14:03
From South east vic
Posted on: 2012/6/6 14:05
yeh post up on gumtree too mate.its free.i dont use ebay anymore due to its fees if you sell.
