can you re-drill steel wheels to change stud pattern?
From Sydney NSW
There's plenty of cheap steel wheels with good offsets but in the wrong stud pattern, is it possible redrill them? I assume they come blank from the factory and are drilled after being pressed, so could maybe be drilled again.
not sure if they have a flat face where they mount to the hub like alloys or are located otherwise.
Posted on: 2012/6/10 16:05
Subject Poster Date
     can you re-drill steel wheels to change stud pattern? elemental_funk 2012/6/10 16:05
       Re: can you re-drill steel wheels to change stud pattern? revhead001 2012/6/11 0:37
         Re: can you re-drill steel wheels to change stud pattern? supafatto 2012/6/11 0:51
           Re: can you re-drill steel wheels to change stud pattern? elemental_funk 2012/6/11 0:55
             Re: can you re-drill steel wheels to change stud pattern? clyons8 2012/6/11 1:00
               Re: can you re-drill steel wheels to change stud pattern? lethal_john 2012/6/11 1:12
               Re: can you re-drill steel wheels to change stud pattern? elemental_funk 2012/6/11 1:15
       Re: can you re-drill steel wheels to change stud pattern? supafatto 2012/6/11 1:24
         Re: can you re-drill steel wheels to change stud pattern? ddgonzal 2012/6/11 2:09
           Re: can you re-drill steel wheels to change stud pattern? Anonymous 2012/6/11 2:14
           Re: can you re-drill steel wheels to change stud pattern? 1200rallycar 2012/6/11 2:14
       Re: can you re-drill steel wheels to change stud pattern? supafatto 2012/6/11 2:27
       Re: can you re-drill steel wheels to change stud pattern? elemental_funk 2012/6/11 2:27
       Re: can you re-drill steel wheels to change stud pattern? elemental_funk 2012/6/11 2:35
