Re: can you re-drill steel wheels to change stud pattern?
are the black wheels in the photo sorta what your after? you can buy them here in aus in dato stud pattern
Posted on: 2012/6/11 1:12
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
Subject Poster Date
     can you re-drill steel wheels to change stud pattern? elemental_funk 2012/6/10 16:05
       Re: can you re-drill steel wheels to change stud pattern? revhead001 2012/6/11 0:37
         Re: can you re-drill steel wheels to change stud pattern? supafatto 2012/6/11 0:51
           Re: can you re-drill steel wheels to change stud pattern? elemental_funk 2012/6/11 0:55
             Re: can you re-drill steel wheels to change stud pattern? clyons8 2012/6/11 1:00
               Re: can you re-drill steel wheels to change stud pattern? lethal_john 2012/6/11 1:12
               Re: can you re-drill steel wheels to change stud pattern? elemental_funk 2012/6/11 1:15
       Re: can you re-drill steel wheels to change stud pattern? supafatto 2012/6/11 1:24
         Re: can you re-drill steel wheels to change stud pattern? ddgonzal 2012/6/11 2:09
           Re: can you re-drill steel wheels to change stud pattern? Anonymous 2012/6/11 2:14
           Re: can you re-drill steel wheels to change stud pattern? 1200rallycar 2012/6/11 2:14
       Re: can you re-drill steel wheels to change stud pattern? supafatto 2012/6/11 2:27
       Re: can you re-drill steel wheels to change stud pattern? elemental_funk 2012/6/11 2:27
       Re: can you re-drill steel wheels to change stud pattern? elemental_funk 2012/6/11 2:35
