« 1 2 3 (4) 5 6 »
Re: Which would be easier to install rotary or CA18DET
From Goldcoast
I agree best case scenario would be to buy one already modified. Only trouble is that I wouldant be able to get that sort of cash together, and also I wouldant get to build it myself. My plan would be to get the engine and gradually buy all of the other parts needed for the build.
Then when I have what I need for the build take it off the road and install the engine.
Posted on: 2012/6/13 10:17
From A.C.T
Yer it is a good exsperiance to build it yourself. but in sayin that i bought an already converted ca ute that needed work and its been off the road since september geting work done, and there are guys on here that have been building theres for over 3 years... you jst have to have a real timeline in your head
Posted on: 2012/6/13 10:22
how many turbo cars you driven? how many rotor cars you driven? you should base your decision on which one you like better, and try build it yourself its much more rewarding
personally i think you should rotorise it! i'll go a heavily ported n/a rotor over a ca18det every day of the week, the sound is just awesome and there's plenty of power. mine used to power skid no worries just stomping it in 3rd gear muhahaha lol
Posted on: 2012/6/13 10:39
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
From Goldcoast
Sounds like fun :)
If I was to run the 12A rotary which gearbox would I be looking at running with it, preferable somthing which wouldant take to much modifying to fit.
Also noticed that Maddat didant have a engine fitting kit available for the 12 rotary would I use the 13B kit instead or is thier another kit available to fit that engine?
Thanks
Andy
Posted on: 2012/6/13 11:11
plenty of fun!
you'd just run the 12a 5spd preferably series 2 or 3, its not that hard to mount the motor in there you just use rx3 front mount system and mods to the tunnel are nothing major. no you can't use the 13b kit from maddat as i think it utilizes the center mounts on a 13b, most people using a 13b will go for the 12a front cover and use the rx3 front mount system
Posted on: 2012/6/13 11:23
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
Stocko 1200 wagon
Just throwing it out there, Sykine is selling a proven 180hp atw A12 with fantastic in/ex manifold designs, arp rod bolts with tuning at his own designed wheel dyno.
Just need a cheap ecu and gearbox which will make it easy to engineer fun and economical to boot. In the end youll have a proven engine capable of much cheaper running costs and installation all up. Add up all the rotary requirements to make it fit, parts & tune and youll see the A12t is a winner.
Posted on: 2012/6/13 14:03
From Goldcoast
Well it looks like I have finally made up my mind :) at this stage its looking like its going to be the N/A Rotary A12.
Thanks for all of your input guys :)
Posted on: 2012/6/13 22:26
From Sydney
If you put a 12A from s2/s3 rx7 it's the easiest swap with most power gains, ive owned n built 13b n ca18det, the ca is a very expensive n longer build that a 13b/12a, if I had to choose between the two I would stick to a rotary..plus when you pull up to the lights n your ported rotar is pulsating the ground everyone stops n stares biggest head turner, but you also attract police haha
Posted on: 2012/6/14 4:25
Can you get that registered? The 12A is 1146 cc, so at the x2 rating that is 2.3 liter equivalent. Too big for Datsun 1200 in some states.
Posted on: 2012/6/14 4:36
From Western Australia
if going with a mazda rx7 gearbox,
I recommend using the rear extension housing from a rear wheel drive mazda 626 unless you want the gear lever to be too far back.
Posted on: 2012/6/14 8:45
1200 Sedan SR17VE + TURBO (Borg Warner twin scroll), 6 Speed, Brembos, Autronic SM4 ...coming together slowly.
Stanza rally car mostly ex works = FIA head, 50mm Mikunis, option one, works diff, 4 pot FIA calipers and vented disc all round, enkies, h...
« 1 2 3 (4) 5 6 »
