Browsing this Thread:
1 Anonymous Users
Re: Which would be easier to install rotary or CA18DET |
its not to far back same as a ca, you can do the extension housing mod to bring it forward
Posted on: 2012/6/14 9:18
www.datsun1000.comCurrent Dato - 68 B20 ute Previous Datos - ca18det 1200 ute 180rwkw 12a montser port 1200 ute 212rwhp Stocko 1200 wagon
From Logan, QLD
as for the money up front, get a loan and buy one, even after you pay the interest, the cost of building one yourself costs alot more then the loan would.
I was looking at nearly $25,000 total spent before I finished mine, but I did buy alot of good parts that were not nessasary, like microtech, big turbo, manifolds, expensive diff etc.
Wish I'd just spent 15k on a finished one.
Posted on: 2012/6/14 10:02
From Goldcoast
That does make sense to buy one already done, but one of the main reasons for the engine swap is to take on a little project. Being as the 12A is going to be a N/A I should imagine that will keep the costs down, no turbo, computer, intercooler ect, and less fabrication costs on labour. I would look at putting some money into a engine rebuild by myself and for the porting obviously not by myself :) All of the bodywork and paint I can do myself. I will have to look into the engineering side on the 12A because I dont want to do the engine swap and find out I cannot get it registerd :(
Posted on: 2012/6/14 23:16
From windsor, sydney
if you want to register it in NSW forget the rotor unless its a 10A but they are very rare at the moment , the ca is about the most popular conversion for bang for buck and the 4agze is a easy one as well
Posted on: 2012/6/16 9:15
WARDMAN ENGINEERING CNC machining Race Car Fabrication Suspension, Brake, Drivetrain modification TIG welding of all metals 0413 595 627
From Goldcoast
Thanks for the heads up. Could you explain why the 4agze is a easy conversion, what would be involved in that one?
Posted on: 2012/6/16 9:33
have a look at smurfs build thread
Posted on: 2012/6/16 10:12
From Perth, West Aussie
they won't even let you have a NA 12A in NSW?? man that blows.. i thought it's weight x 3 in cc's NA and 2.67 or thereabouts for turbo for cars under 1200 kgs in the national guidelines? you should come to WA, the govt makes you put SR20 turbos in everything ;)
Posted on: 2012/6/16 10:23
From Narellan,Sydney
Because they a rotor it dosnt work out the same as a normal piston engine
Posted on: 2012/6/16 10:29
All stainless steel-mild steel Sheetmetal and tube work All types of welding Custom metal polishing BSA custom fabrication 0415 904 474
From Goldcoast
Could only find the the smurf build with the evo 8?
Posted on: 2012/6/16 11:15
Done right an A16 can make 200hp at wheels with more if needed. Look up a Finnish member he has the fastest A series about 250hp atw with boost and going for more in his 79mm bore 1600cc A15. CA18 is the easiest though agreed.
Posted on: 2012/6/16 15:18
