« 1 (2) 3 4 5 »
Re: Sunny Truck Project
From Boredomville Melbourne
Nice, you lathed up the threaded sleeves?
Posted on: 2012/6/16 3:54
B110 sedan: L series and 5 speeds, the way they should have been
From A-TOWN
nope, otomoto kit.
Posted on: 2012/6/16 9:58
From mandurah
awesome setup man should stop good ,did you shorten the struts?
love the longchamps ,hoping to get a set for my ute but i need adjustable lcas so i can pull the wheels in and stop the rubbing with my 13X7s
get the updates coming ,looks sick
Posted on: 2012/6/16 16:30
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From A-TOWN
yeah took about 100mm out of them. No need to pull the wheels in, just add more camber or run smaller tyres.
Thinking i mite run the 165s on the 8s on the back and get some 155s for the front.
Ill get the updates going soon, i bought the 4age setup of a bloke who had it in his ute but its not lining up 100%, with the tailshaft, gearbox and engine all fitted the engine still needs to go back about 15mm to clear the sway bar and i want to run a 24mm sway bar soon so it may have to go back a little further. I cant be #OOPS#ed shortening the tailshaft so thinking i mite modify the sump for clearance.
apart from that everything else should be pretty straight forward. just need to fab up some engine mounts and the rest should basically bolt in, have the full loom, fuel setup and exhaust from the other ute.
Posted on: 2012/6/16 23:27
Can't you space.away bar down off the chassis for clearance? I did for l series with blocks as only needed 20mm clearance odd. Otherwise a mad dat away bar?
Posted on: 2012/6/16 23:51
From A-TOWN
nope, either modify the sump or shorten the tail shaft, i dont think the bloke who i bought the setup off was running a sway bar, ive got a bit of room behind the engine to play with so looks like shortening the saft will be the best option. 20mm should do it.
Posted on: 2012/6/17 6:35
From MOOROODUC - Victoria
G J drivelines did my tailshaft for $120 (I think) - they are in Dandenong
Posted on: 2012/6/17 8:56
1200 Coupe (Beacon red)
1200 Ute Auto Silvia in disguise (Shockwave blue)
1200 Sedan (Kermit green)
Tail shaft city in Preston did,mine. Nice guys, no BS A.D. he's doing his own hot rod currently - lives a chat
Posted on: 2012/6/17 11:13
From A-TOWN
small update
out with this
in with this, then out, then in, then out a few more times.
sat like this for a bit
then made some of these
bought a pair of these
how its looking now
started a #OOPS# to do list
Posted on: 2012/8/19 10:26
Re: Sunny Truck Project 4AGE
From brisbane
love the ute mate very nice work on the front struts also keep up the great work go the utes
Posted on: 2012/8/19 22:53
« 1 (2) 3 4 5 »
