« 1 (2)
Re: Nissan A12 Carburator jets
From Colombo Sri Lanka
Hi David,
So i am going to change the Main jets to
primary, A14: 104
secondary, A14: 150
is it ok ?
or else can i use A 12 Jet Sizes for this A14 carburetor
primary, A12: 96
secondary, A12: 150
Please suggest best thing according to your knowledge
Thanking you
indika
Posted on: 2012/6/18 9:02
I would start with the A14 jets.
Jets are first selected for the size of the venturis.
Posted on: 2012/6/18 11:02
Ok then i will proceed with the A 14 jets
Thank you
Indika
Posted on: 2012/6/18 12:07
Hi DD,
My car is now running well because of your help.Thank you very much david.
Yesterday I replaced the main jets of carb. Now its pulling well without any misses. I found only 104 size for primary and 145 size jets with carburetor repair kits in local market. Any way its running well with 145 size for secondary.
The old jet sizes was 87 for primary and 97 for secondary
and now I am going to check fuel consumption
Thank you again
Indika
Posted on: 2012/6/25 4:39
Edited by indikanospam on 2012/6/25 5:02:07
glad to hear it is an improvement.
wow those old jets were very small. Check the size of the air bleeds, because they are like very small to match (otherwise it probably would not have run at all).
Jets and air bleeds go together.
By the way, repair kits in USA do not include jets.
Posted on: 2012/6/25 5:09
Hi dd,
The repair kit was Datsun sunny B210 suitable model (that's why secondary jet size was 145) .I used jets only from that kit because air bleeds not matching to my carb.(Totaly different)
Posted on: 2012/6/25 5:47
« 1 (2)
