urgent turn signal part id
From Brisbane
i was just disconnecting the turn signal assembly in order to remove in prep for installing a new steering column busch when this part fell out.
what is it and more importantly where does it go??
jpg  P1010629.JPG (28.11 KB)
10135_4fe0241a6fb45.jpg 267X200 px
Posted on: 2012/6/19 8:03
Re: urgent turn signal part id
From Canberra
http://www.ebay.com.au/itm/SWITCH-COM ... ories&hash=item3365cc39e1
IT looks like it could be off the connector which would be under the dash.. hard to tell
That's if it is part of the turn signal switch or unit :S
Posted on: 2012/6/19 8:22
From Canberra
The part connected under the Dash?? other wise have a look at that link to ebay and see if u can notice the part in which it is actually missing off the turn signal switch
jpg  20092281604.jpg (20.86 KB)
16063_4fe02909658f3.jpg 400X256 px
Posted on: 2012/6/19 8:23
From Canberra
http://datsun1200.com/modules/mediawi ... ex.php?title=Turn_Signals
Otherwise have a quick look here to see if u might notice it.
Posted on: 2012/6/19 8:28
From Brisbane
yeah cheers, shouldve mentioned id already looked at techwiki. can't see it there.
any other ideas?
it came out after i loosened the wiring on the stalk side. now the stalk is hanging limp.
Posted on: 2012/6/19 8:31
From Brisbane
i've found where it goes. hard to describe. in behind the wiring on the opposite side to the stalk. slides in a slot and serves as some kind of contact.
one prob solved. now no indicators!
help
Posted on: 2012/6/19 9:00
From Perth WA AUS
Might be time for a new unit?
Posted on: 2012/6/19 9:02
Datsun 1200 2Dr sedan.
From Brisbane
was working fine before i decided to pull it apart. just got to double check a few things i guess
Posted on: 2012/6/19 9:24
