« 1 2 3 (4) 5 6 »
Re: Engine validation urgent. [PLEASE HELP ME]
From Trinidad and tobago
Hi again,Swapping to the 56A Gearbox,any modifications to the mounts?
Or a straight bold up.
Posted on: 2012/6/1 2:42
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Bolt straight up to a15 use the a12 flywheel and hd clutch.
You don't seem to do heaps burnouts etc so should be fine
Posted on: 2012/6/1 3:41
60-series gearbox is a much better choice for an A15. The ratios are exactly the same, but it is strong enough for an A15.
But a 56A will work. Same driveshaft, same flywheel, shifter, clutch, etc.
The only thing that is different is the gearbox crossmember (mount). The B110 original setup has the correct crossmember and mount for a 56A 4-speed.
You can use A15 flywheel or A12 flywheel -- but the flywheels use different release bearing Sleeves.
* With A12 flywheel, use short bearing sleeve OR engine plate (but not both)
* For smoother low-speed driving, use the A14/A15 flywheel. This requires both short bearing sleeve + engine plate
Engine Plate:
A12 flyweel: 28 mm thick
A14/A15: 30 mm thick
Posted on: 2012/6/1 7:43
Thanks,Not sure if i asked this question before,But it seems that all a series distributors can interchange between engines,Want a12 distributor into a15.But is tere any modification needed to the plates,under the dizzy?
Posted on: 2012/6/27 20:25
Street Sleeper!
Early A-series and Late A-series distributors differ. The changeover was 1974.
Prior to 1973 the distributors bolt on different. A12 engine after 1973 uses a different distributor. So A12 distributor from 1974-1995 fits an A15.
If you want to use 1967-1973 distributor in A15, I'm sure it will work, but don't have details of exactly what to do. Use the early plate probably.
If you want to use 1974-up A12/A13/A14/A15 distributor in early A12, click Using Newer Distributor.
Posted on: 2012/6/27 23:36
Went out a took a few photos.
Confirmed Early distributor will work in A14/A15. Just use the newer plate on the bottom of the distributor -- and it needs a bit of filing to bolt it on.
For more photos & details, click Using Older Distributor.
Posted on: 2012/6/28 1:46
Thanks DD For all your info.
Engine was purchased today so Weekend am starting to buy my parts Rings,Main and connecting Rod Bearings.Timing Chain.etc...
Posted on: 2012/7/5 3:21
Street Sleeper!
Hey Me again.What is the bore of the a15?
Posted on: 2012/7/8 2:46
Street Sleeper!
Standard bore is listed in the A15 article. Click for details.
A clean-up overbore is not uncommom, so you should measure your engine. This type of overbore is not done to increase HP. By contrast an overbore of 2.5 or 3.0 mm is done for HP increase. The latter will increase the displacement of an A15 to 1608cc.
Posted on: 2012/7/8 2:57
I baught 79mm rings today Will work? ,Told me that its the correct size,So ill have to get the engine measure.then.
Posted on: 2012/7/8 3:00
Street Sleeper!
« 1 2 3 (4) 5 6 »
