Panel changing
From Goulburn NSW
Online
Hi guys who out there has changed the front aprin themselves mine on my new shell is slightly damaged and doesnt line up with the gaurds.I have a brand new one so im going to try fitting it myself,first ill need to grind down the welds then hopefully it will just drop off.Any tips?
Posted on: 2012/6/28 8:56
Re: Panel changing
From Nyngan, nsw Australia
are you using aftermarket guards or original's, bolt all together so you can see how it sits, tack it on, probably measure aswell before do so
Posted on: 2012/6/28 11:34
living is good,.....
Re: Panel changing
From Goulburn NSW
Online
Well guys im proud off myself i changed the front aprin on my ute today,everything lines up perfectly and is tacked on.Thought it was going to be hard,just ground down the welds and as expected just fell off.
Posted on: 2012/6/30 7:40
Re: Panel changing
yeah not much holding them on!
Posted on: 2012/6/30 8:54
Re: Panel changing
From Perth WA AUS
Well done mate, It's a good feeling when you do it your self and it works out OK :)
Posted on: 2012/7/1 12:35
Datsun 1200 2Dr sedan.
Re: Panel changing
From south australia
Welded on? Every one I have come across has been bolted on? That's weird.
Posted on: 2012/7/1 21:47
Re: Panel changing
From Goulburn NSW
Online
welded onto the radiator support,bolted to the gaurds.
Posted on: 2012/7/2 1:55
