Wiper main arms to fit isotta arms?
From Narellan,Sydney
Just received my isotta chrome wiper arms but the standed Datsun main arm seems to be 1 peice and dosnt click into the clip like the isotta parts.any1 changed over arms and worked out to use?
Posted on: 2012/7/2 8:30
Re: Wiper main arms to fit isotta arms?
From Seattle, WA
If you have an Isotta arm, why do you want to fit a 1200 arm?
Yes, original 1200 Wiper Arms are one piece:
original 1200 Wiper Blades
Posted on: 2012/7/2 9:33
B110 sedan: L series and 4 speeds, the way they were
The isotta arm is only the blade bit that holds the wiper blade.so in need of the arm that clips in and bolts to the car.how did you put photos up like that and I'll show you ^^
Posted on: 2012/7/2 10:06
All stainless steel-mild steel Sheetmetal and tube work
All types of welding.
BSA custom fabrication 0409930474
From Seattle, WA
You can link to photos from other web sites. Click Reply (don't use the quick reply box) then you will have the Images button. Or you can use the Upload button to upload a photo from your hard drive.
Posted on: 2012/7/2 10:11
Posted on: 2012/7/2 10:29
These are the blade arms and it come with some different clips.maybe I just need a main arm with this clip and the same length as the datto main arm?
Posted on: 2012/7/2 10:31
From Seattle, WA
OK, so the Isotta is a Wiper Blade. There is no main arm and secondary arm, there is only Blade and Arm.
In the photos I see the Isotta blade comes with a pin-type attachment. Which adapter clips does the Isotta come with? Just the standard j-hook clip?
Posted on: 2012/7/2 18:24
Yep spot on that's exactly Wat it is
Posted on: 2012/7/2 21:58
