Welders
From Goldcoast
Hi just wondering if anyone with some welder knowledge could tell me if this welder would be suitable for welding up some panels on my car?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=261056942622
Thanks
Posted on: 2012/7/5 6:09
Re: Welders
Will weld. Just not great most likely.
I thought same and got a gasless but the esab is scoop much better.
Think Of.spares and repairs too. That will be a throw away mig
Posted on: 2012/7/5 6:56
Re: Welders
From Melbourne, Australia
Not ideal as by the looks of it there doesn't seem to be a dial adjustment for the amps, only wire speed.
Ideally you need one where you can adjust both as you will need to make smaller adjustments than 4 different settings that machines like this one offer.
The amperage (200) is more than enough and will handle quite thick steel plate but when it comes to welding panels you need fine adjustment way down low or you will blow holes in panels and frustrate the $hit out of yourself trying to not to!
Posted on: 2012/7/5 7:06
Current Fleet-
1996 R33 GT-R Skyline
1996 Falcon XH XR6 Ute
1977 Datsun 1200 Ute A14 (Fergus)
2012 VW Passat TDI Wagon
Re: Welders
From MOOROODUC. Victoria
I waited... saved up and got one of these .... it's a great welder
http://www.ebay.com.au/itm/Lincoln-18 ... lding&hash=item2a1f8e9600
Posted on: 2012/7/5 7:50
Re: Welders
Due to no gas you will most likely get perosity(air bubbles in weld) causing the weld to be weak, and when you grind it back it will have pin holes in it
Posted on: 2012/7/5 8:41
Re: Welders
using gasless mig wire, reduced chance of perosity though (still wont be a great weld compared to a gas mig though- but you could be happy with it still)
Posted on: 2012/7/5 15:38
Re: Welders
From Goldcoast
Ok thanks for your input guys :)
Posted on: 2012/7/6 23:08
