« 1 (2) 3 4 »
Re: Camber Adjustment
Shoota's got it.
the front right tyre actually rubs at the back of the wheel arch
Camber is left/right lean of the wheel, not forward/back.
Your caster is off. Probably the bushes like Shoota says. Take them off and look. Or just see if you can rock the tyre forward and back.
Don't use nolathane or any kind of poly bushings on the caster rods. Racers do that. Daily Driver will eventually crack with poly bushings.
Get genuine Nissan bushings or other Original Equipment type bushings.
Only 4 bushings.
54476-W5000 Tension rod bushing (2 per side) $2.73 each at Nissan USA
Take them off first to verify it is that. See photos at Caster (click for photos).
Posted on: 2012/7/5 5:50
From Western Australia
cheers DD
I found this:
"If you want your 1200 to have some -ve camber (factory spec is +1.5 degrees), just move the lower control arm mounts in the cross member. Redrilling the mounts about 10mm outward from their original position will result in about 0.5 degrees of negative camber, and will definitely make the car handle better, making it less susceptible to understeer when cornering fast. "
from here: http://martybugs.net/DatsunMods/suspension.cgi
If I did that RHS only would that help?
here is the wheel align report:
http://datsun1200.com/modules/myalbum/photo.php?lid=24700
Posted on: 2012/7/5 7:20
1974 1200 Ute - Build
From Melbourne, Australia
Dude, remove camber from your mind!!!!!!!
You need to worry about caster!!!!!
You don't need to worry about camber till you've put more than an A12 in your rocket and you're going around corners fast or you're putting in a set of coilovers and drastically lowering the height.
When you are at this point, you can make or buy adjustable lower control arms then you can play around with the settings. Drilling new holes whilst doable is a bit neanderthal compared to adjustables.
But fix the first issue, then worry about camber.
Posted on: 2012/7/5 7:36
Current Fleet-
1996 R33 GT-R Skyline
1996 Falcon XH XR6 Ute
1977 Datsun 1200 Ute A14 (Fergus)
2012 VW Passat TDI Wagon
I recently bought a pair of struts for $150 from a member on here, and they came with near new wheel bearings, brake rotors and calipers (and some dodgy cut springs, however, I digress)
The guys at WA suspensions are great, but you have to keep in mind they have some pretty limited "brand specific" knowledge. They fixed the front end of my ute up nicely, but the old B310 ball joint and tie rod secret went straight through to the keeper until after I got it back :(
From personal experience, I would def look at bushes etc before looking to put your struts in a 10 tonne press and getting busy wit it.
Posted on: 2012/7/5 7:40
Posted on: 2012/7/5 7:47
first link.
weird the report does indicate excessive positive camber compared to the passenger side. could it be the strut is actually bent back and in?
indicative of hitting something from that side?
if the base of the strut was pushed in,the top of the tyre woulp be further out then the base, and it could be pushed towards the rear of the wheel arch.
the castor isnt much of an issue on that report, but worn bushes would show up more when drivg, so the alignemnt may not pick them up,.
Posted on: 2012/7/5 15:36
That's why the bushing should be inspected before buying new ones. I'm sure BeeJJ is not going to buy them first, only to find out they are perfectly fine and didn't solve the problem. The Caster article gives a spec for the bushing thickness.
If the wheel alignment guys are correct that the right strut is bent, simply replace the strut. It is non-adjustable in stock form.
But shoota's still correct, camber has little to do with the tyre hitting the back of the wheelwell. A bent strut is unlikely to cause that, as it is fixed at the bottom by the caster rod. A bent spindle might cause it.
What's funny is that TWO wheel alignment shops couldn't fix it. Back in 1981, that was the first repair to my 1200 -- the right wheel hit the back of the wheelwell, and the local alignment shop fixed it.
I can't read the handwriting to see which parts were changed.
Posted on: 2012/7/5 18:13
IM more amazed you have receipts BAck to 1981.... Hello Mcfly!
Posted on: 2012/7/5 23:07
cheers
Yea thats stylish that you still have receipts from back then! I see what you mean, I can't decipher that writing either. The shop did claim the right strut was bent in and back which helps all the theories discussed earlier. Now I need to find another right strut, anyone got a spare?
Posted on: 2012/7/5 23:23
haha, I don't have all receipts, but saved my first one.
OK, i figured it out.
In the PARTS side, it only has one part:
1 - used R. lower control arm $32.50
For a wheel going back too far, that makes more sense than a damaged strut.
Price of used LCA hasn't gone up in the last 30 years!
Posted on: 2012/7/5 23:57
« 1 (2) 3 4 »
