Browsing this Thread:
1 Anonymous Users
Re: Master cylinder mod to suit 4 wheel discs |
From Melbourne, Australia
yeah it got the better of me today
first couple of times the rear passenger calliper was the only hot brake (walking around the car burning my finger tips off trying to figure out what was going on)
next couple of times it was both backs (and definitely not fronts)
today it was all four, i was cracking the nipples on the master to release the pressure (did it twice to get home, about 2km)
the front circuit had more pressure, but i was cracking it first so im not sure if that's why not much released from the back circuit when cracking it open second
[edit] using dot 4, lids on new master say to use dot 3 but i ignored that
Posted on: 2012/7/7 11:36
From windsor, sydney
Check that the pedal is coming all the way back and that the push rod has play in the back of the master cyl piston , the piston must come all the way back to the circlip in order to expose the fill ports in the resivoir . It sounds like the push rod is too long and this could cause your hard to bleed and holding pressure issues
Posted on: 2012/7/7 12:46
WARDMAN ENGINEERING CNC machining Race Car Fabrication Suspension, Brake, Drivetrain modification TIG welding of all metals 0413 595 627
good idea wards, will do
the new master has a small bolt that screws up in to the barrel, between where the brake lines screw in, any know what that is/does?
Posted on: 2012/7/7 12:53
From hastings,vic
master needs spacing with the shims on the fire wall/changing rod length/adjust peddle stop if you got pressure at master holding brakes on master is not releaving pressure you will have huge problems bleading because not using fluid from resiviour piston not back far enough fill port not open
Posted on: 2012/7/7 14:21
taking up room at home 3 now 2 1200 sedans,3 now 2 1200 coupes,3 now 2 1200 utes 1 1000 wagon,2 s13 silvia's,tranzit tray hzj75 cruzer tray(for sale) and allways changing
From South east vic
Holds the pistons in
Posted on: 2012/7/7 14:22
1200 coupe under construction
From hastings,vic
small bolt holds half of master together, circlip other half
Posted on: 2012/7/7 14:25
From Geelong, Vic
ah yeah that too. would explain it. one of the main thins you should check when putting any master cylinder in only ever had that problem with a clutch so didn't think of that
Posted on: 2012/7/7 14:26
so yeah... checked out the whole pedal operation
stupidest thing ever
the brake light switch was wound in so far it was holding the pedal on just enough...
i think with the new master the distance was slightly different and it amplified the problem
Posted on: 2012/7/9 12:06
FECK!!!
went to get sound test today, brakes locked up again, i dunno what the feck is going on, i can't believe it, i'm tearing my hair out now
Posted on: 2012/7/10 5:47
From Boredomville Melbourne
Maybe needs further shim for clearance/free play
Posted on: 2012/7/10 6:03
B110 sedan: L series and 5 speeds, the way they should have been
