« 1 (2) 3 »
Re: Master cylinder mod to suit 4 wheel discs
From Melbourne, Australia
yeah it got the better of me today
first couple of times the rear passenger calliper was the only hot brake (walking around the car burning my finger tips off trying to figure out what was going on)
next couple of times it was both backs (and definitely not fronts)
today it was all four, i was cracking the nipples on the master to release the pressure (did it twice to get home, about 2km)
the front circuit had more pressure, but i was cracking it first so im not sure if that's why not much released from the back circuit when cracking it open second
[edit] using dot 4, lids on new master say to use dot 3 but i ignored that
Posted on: 2012/7/7 11:36
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From windsor, sydney
Check that the pedal is coming all the way back and that the push rod has play in the back of the master cyl piston , the piston must come all the way back to the circlip in order to expose the fill ports in the resivoir . It sounds like the push rod is too long and this could cause your hard to bleed and holding pressure issues
Posted on: 2012/7/7 12:46
WARDMAN ENGINEERING
CNC machining
Race Car Fabrication
Suspension, Brake, Drivetrain modification
TIG welding of all metals
0413 595 627
good idea wards, will do
the new master has a small bolt that screws up in to the barrel, between where the brake lines screw in, any know what that is/does?
Posted on: 2012/7/7 12:53
1200 Coupe Rallycar
From hastings,vic
master needs spacing with the shims on the fire wall/changing rod length/adjust peddle stop
if you got pressure at master holding brakes on master is not releaving pressure
you will have huge problems bleading because not using fluid from resiviour
piston not back far enough fill port not open
Posted on: 2012/7/7 14:21
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
From South east vic
Holds the pistons in
Posted on: 2012/7/7 14:22
1200 coupe under construction
From hastings,vic
small bolt holds half of master together, circlip other half
Posted on: 2012/7/7 14:25
From Geelong, Vic
ah yeah that too. would explain it. one of the main thins you should check when putting any master cylinder in
only ever had that problem with a clutch so didn't think of that
Posted on: 2012/7/7 14:26
so yeah... checked out the whole pedal operation
stupidest thing ever
the brake light switch was wound in so far it was holding the pedal on just enough...
i think with the new master the distance was slightly different and it amplified the problem
Posted on: 2012/7/9 12:06
1200 Coupe Rallycar
FECK!!!
went to get sound test today, brakes locked up again, i dunno what the feck is going on, i can't believe it, i'm tearing my hair out now
Posted on: 2012/7/10 5:47
1200 Coupe Rallycar
From Boredomville Melbourne
Maybe needs further shim for clearance/free play
Posted on: 2012/7/10 6:03
Was B110 Sedan: L series and 5 speeds, the way they should have been
Now A10 Stanza: L series and 5 speeds...
« 1 (2) 3 »
