so then i did all the small stuff like fuel lines, radiator hoses, heater hoses...all that not so exciting stuff
speedo cable was one another thing that needed to be changed. standard one wasn't quite long enough. I was pretty sure that i had a 120y cable around somewhere and that id figured out a while ago that it would do the job....but it seems to have gone awol.
local wreckers had a 120y with a good speedo cable in it and it turned out to be the correct length
took a pic of it compared to the standard 1200 cable
then i needed a gear knob, didn't really want one of the normal cheap aftermarket ones that are around and also didn't want to wait for one off ebay. still had some 50mm 7000 series (i think) billet that i had left over from a uni project so i figured that would turn into a nice gear knob, man i love lathing good quality alloy
im pretty happy with how it turned out, especially since the lathe has developed a bit of a vibration and what looks to be a bit of run out on the chuck
also got some pics of how the engine sits
height of the plenum from the top of the guards. measured next to the throttle cable bracket
back of the left hand rocker cover to the main plane of the firewall
did the same thing with the back of the plenum, measured 110mm to the gasket surface on the back of the plenum
and as it now sits all ready to run. just need to do the overflow bottle and rocker cover breathers
