Calibrating Fuel Gauge
From Western Australia
Hey,
Just wondering if anyone knows how to adjust the fuel gauge on this style dash:
Basically my gauge works but reads about 1/3 too low all the time. i.e when I fill up full it only shows 2/3 full
thanks
Posted on: 2012/7/12 11:11
Re: Calibrating Fuel Gauge
From Perth WA AUS
Have you tried cleaning the resistor/contacts in the sender unit? It normally fixes the problem.
Posted on: 2012/7/12 11:49
Datsun 1200 2Dr sedan.
Cheers Levey. No I haven't how do you do this? Is there a wiki article?
Posted on: 2012/7/12 12:04
1974 1200 Ute
1971 1200 Sedan
From Seattle, WA
factory Fuel Gauges are non-adjustable.
The fuel "sender" is the part that goes bad (the resistor in the fuel tank).
Click Fuel Sender, especially note the Specifications section.
Posted on: 2012/7/12 19:32
B110 sedan: L series and 4 speeds, the way they were
cheers DD
Posted on: 2012/7/13 0:36
1974 1200 Ute
1971 1200 Sedan
From Perth WA AUS
Pull it out and check for corrosion, very gently clean the winding (resistor) and contact with fine sandpaper.
Any corrosion will alter the resistance and give the guage a false reading.
Hope this helps, It worked for me.
EDIT: also check the float for leaks.
Posted on: 2012/7/13 10:09
awesome thanks Levey
Posted on: 2012/7/13 11:36
1974 1200 Ute
1971 1200 Sedan
